Primer on setting up 5th axis?
03 Sep 2023 00:15 #279684 by Halbear
Primer on setting up 5th axis? was created by Halbear
Hi all,
I don't know if the search function is working for me but I get no results searching for "set up 5th axis," or much of anything. I apologize if this question has been asked a million times but Id like to get my C axis going.
I'm in the process of building a trunnion table and have been playing around with XYZA, with the C rotational axis wired to the Y on the 7i96s (running off Debian12) for now to check the build. Ideally I'd like to program sample stuff for it but I can't find a primer or instructions anywhere on how to do it.
Many thanks,
Hal
03 Sep 2023 01:03 #279687 by tommylight
Replied by tommylight on topic Primer on setting up 5th axis?
If you do this in google:
"set up 5th axis" site:linuxcnc.org
it returns this:
www.google.com/search?q=%22set+up+5th+ax...sclient=gws-wiz-serp
03 Sep 2023 01:41 #279692 by Halbear
Replied by Halbear on topic Primer on setting up 5th axis?
Hey thanks Tommy, it gave me some results I'd already looked at but new ones too. I didn't think to add the Site restriction
Time to create page: 0.124 seconds
