- LinuxCNC
- General LinuxCNC Questions
- Question about acceleration and deceleration of linuxCNC linear movement
- lqb
04 Sep 2023 09:46 #279807
by lqb
Question about acceleration and deceleration of linuxCNC linear movement was created by lqb
Hello, everyone.
In the "tpUpdateCycle" function in the "tp.c" file, the calculation of the acceleration phase is done with the "tpCalculateRampAccel" function and the "tpUpdateDistFromAccel" function, but I can't see where the calculation of the deceleration phase is done.
- lqb
04 Sep 2023 11:20 #279812
by lqb
Replied by lqb on topic Question about acceleration and deceleration of linuxCNC linear movement
Sorry, I looked into the function "tcUpdateDistFromAccel" again, and when a line segment is added and the final velocity of the segment is 0, it should be a decelerated displacement.
This seems to mean that I have to add three displacements to do acceleration, uniform velocity and deceleration
- Thank you received: 4138
05 Sep 2023 03:19 #279917
Replied by rodw on topic Question about acceleration and deceleration of linuxCNC linear movement
Correct, Linuxcnc accellerates at max velocity until it reaches requested velocity, then decellerates at the same rate to get to the end point accelleration. If you graph this in halscope, you will see the classic trapezoid.
There are a few other factors that come into play regarding segment length and the look ahead to the next segment in the real world.
The following user(s) said Thank You: lqb
- LinuxCNC
Time to create page: 0.134 seconds
