is it possible to use linuxcnc only as DRO?
- Online
- Thank you received: 4648
09 Sep 2023 18:17 #280341
Replied by andypugh on topic is it possible to use linuxcnc only as DRO?
I think that the answer here is not to load the interpreter and motion system.
You can just load a Glade GUI and a few encoder counters.
Unforunately mdro appears so need the rest of the LinuxCNC system to operate, so doesn't quite work in this mode.
The following user(s) said Thank You: RobotMatic
- RobotMatic
- Thank you received: 25
10 Sep 2023 14:54 #280403
by RobotMatic
Replied by RobotMatic on topic is it possible to use linuxcnc only as DRO?
I thought about the GUI. But consider it better to try using MDR0 on Linuxcnc 10.0 and have the entire system available to add functionality in the future.
I installed the .ISO x86 2.9, tried to update to 2.10 but only the .DOC was updated
I am making a very big effort to understand how I can install a complete Linuxcnc 2.10 but I cannot find the .ISO
I am very excited about using MDRO I think it is a great solution to what I am looking for. I'm moving forward little by little.
The Linuxcnc Studio allows me great work advances. I must continue!! sorry for asking so many questions!!!
- Online
10 Sep 2023 16:41 #280409
You don't need an ISO to run 2.10. If you have 2.8 on Buster then that can be upgraded to LinuxCNC 2.10 without any changes to the OS.
- RobotMatic
10 Sep 2023 17:12 - 11 Sep 2023 01:51 #280414
by RobotMatic
Really?? I didn't know that it could do it.
If i change the repository to master, it update to 2.10?
I'll do it, thanks for your help !!!!!!!
Last edit: 11 Sep 2023 01:51 by RobotMatic.
Time to create page: 0.270 seconds
