STMBL pseudo absolute resolver behaviour
2 years 9 months ago #292168 by JackRay
Hello everyone,
I can't save the axis positions of my machine as soon as I quit linuxCNC . I would like to avoid redoing the original settings as soon as I restart my machine.
i think than I have correct confguration.
[TRAJ]
AXES = 5
COORDINATES = XYZBC
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 120
MAX_VELOCITY = 150
POSITION_FILE = /home/jack/linuxcnc/configs/5axescnc/position.txt
NO_FORCE_HOMING = 1
Can you help me .
Thank you
2 years 8 months ago #292367 by freemoore
Hi Freak,
I would guess virencq above means, please will you share all hardware files for your updated version of STMBL? From your earlier post it sounds like you might have resolved the stmbl power stage issue, which seems to be the thing that has left that project apparently stuck for years with information slowly drying up.
I understand that the devs are likely busy with other things, as some responses on the gitter channel seem to show. For myself, it's been rather difficult to learn to use what they've made due to info being sparse, but there are obviously a fair number of people who really want access to a) working STMBL drives and b) enough information to make them user-friendly.
My point is that if you have a working power stage with non-obsolete components, maybe enough people can use your design to start making stmbl drives again that the project will come back to life. As another commenter said somewhere, such an amazing amount of high-quality work went into STMBL that it's a big shame that it isn't more usable.
I've just got back around to making a test rig with: linuxcnc 2.9.2 -> mesa 7i94 -> SS_5ABOBD firmware -> STMBL -> Fanuc 20F 23nm redcap servodrive with (I think) incremental encoder. I've an old Fanuc S420F robot arm which came super cheap with all 6 motors but no control board, and have been trying on and off for a few years to get it going. First movement in some time was yesterday evening; hopefully this time around I can get past the test bed stage and have the actual robot moving. I hope to post details about my config in case anyone else can use it, when I get a chance.
Probably going on a bit here, but just to say, it'd be great to see more life in the stmbl project again.
2 years 2 months ago #308293 by Freak
Hi everyone,I recently fixed an issue with the original state machine for simulating absolute encoder behavior, as I forgot to post it here earlier. I've now implemented a simple state machine class that's been working well for me. In the future, I plan on adding this to my robot configuration repository.Please note that I don't receive notifications when topics are updated in this forum, so I apologize if I respond late.Here's how it works with the INI file:
... [JOINT_1] TYPE = ANGULAR UNITS = degree MAX_VELOCITY = 77.0 MAX_ACCELERATION = 199.0 MIN_LIMIT = -160 MAX_LIMIT = -5 HOME_ABSOLUTE_ENCODER = 2 HOME_OFFSET = -90.0 HOME = -90.000 HOME_SEQUENCE = 0 ...
In the Hal file I have:
loadusr -Wn pseudo_abs_encoder ./pseudo_abs_encoder.py num_chans=6 ...net m0abs_enc_posfb pseudo_abs_encoder.encoder-position-0 net m0abs_enc_offset pseudo_abs_encoder.offset-0 => sum2.3.in0 net m0abs_enc_posfb => sum2.3.in1 net m0posfb sum2.3.out => joint.0.motor-pos-fb net m1abs_enc_posfb pseudo_abs_encoder.encoder-position-1 net m1abs_enc_offset pseudo_abs_encoder.offset-1 => sum2.4.in0 net m1abs_enc_posfb => sum2.4.in1 net m1posfb sum2.4.out => joint.1.motor-pos-fb net m2abs_enc_posfb pseudo_abs_encoder.encoder-position-2 net m2abs_enc_offset pseudo_abs_encoder.offset-2 => sum2.5.in0 net m2abs_enc_posfb => sum2.5.in1 net m2posfb sum2.5.out net m3abs_enc_posfb pseudo_abs_encoder.encoder-position-3 net m3abs_enc_offset pseudo_abs_encoder.offset-3 => sum2.6.in0 net m3abs_enc_posfb => sum2.6.in1 net m3posfb sum2.6.out => joint.3.motor-pos-fb net m4abs_enc_posfb pseudo_abs_encoder.encoder-position-4 net m4abs_enc_offset pseudo_abs_encoder.offset-4 => sum2.7.in0 net m4abs_enc_posfb => sum2.7.in1 net m4posfb sum2.7.out => joint.4.motor-pos-fb net m5abs_enc_posfb pseudo_abs_encoder.encoder-position-5 net m5abs_enc_offset pseudo_abs_encoder.offset-5 => sum2.8.in0 net m5abs_enc_posfb => sum2.8.in1 net m5posfb sum2.8.out => joint.5.motor-pos-fb setp pseudo_abs_encoder.res-offset-0 0.1428 setp pseudo_abs_encoder.res-offset-1 0.6960 setp pseudo_abs_encoder.res-offset-2 0.1893 setp pseudo_abs_encoder.res-offset-3 -2.0864 setp pseudo_abs_encoder.res-offset-4 1.36027 setp pseudo_abs_encoder.res-offset-5 0.8230 setp pseudo_abs_encoder.scale-0 2 setp pseudo_abs_encoder.scale-1 2 setp pseudo_abs_encoder.scale-2 2 setp pseudo_abs_encoder.scale-3 5 setp pseudo_abs_encoder.scale-4 4 setp pseudo_abs_encoder.scale-5 4
2 years 2 months ago #308294 by Freak
Hi freemore, I'll publish my stmbl implementation soon, this week probably. You will get more info in the stmbl matrix chat.
The following user(s) said Thank You: JackRay
Time to create page: 0.107 seconds
