Repositioning the toolpath
11 Sep 2023 18:47 - 11 Sep 2023 18:50 #280487 by krigby
Repositioning the toolpath was created by krigby
I don't even know exactly how to ask this question, so please forgive my ignorance.  I will try to explain.I generated G code to turn a part on my lathe using Fusion 360 and saved it as an NC file.I open the file in Axis and the toolpath is at the extreme positive end of my Z axis, but I want it located at the negative end or maybe in the middle somewhere.When I try to run the program Axis says the toolpath would exceed the limits, which is true.I've attached a screenshot of the Axis screen so you can see the current setup.  I would like the 'left' end of the part to be closer to where the tool currently is (-320 after homing)  Preferably, I would like the left end of the part to be around the -250 mark.  The part is just over 60 MM long.Any help is greatly appreciated.
Last edit: 11 Sep 2023 18:50 by krigby.
12 Sep 2023 06:00 #280524 by Aciera
Replied by Aciera on topic Repositioning the toolpath
Sounds like you need to set your G54 work offset. Maybe this helps:
linuxcnc.org/docs/html/gcode/coordinates.html
12 Sep 2023 06:36 #280526 by tommylight
Replied by tommylight on topic Repositioning the toolpath
Off topic, sorry
@Aciera,
Why are you up so early? :)
BTW, i am not up, have not slept yet, fixing and installing some more old laptops in the shop. :(
Got 6 working, from 486 to PIII 500.
12 Sep 2023 11:20 #280532 by Aciera
The early bird catches the worm. Although it wasn't really as early for me as it was late for you, I think.
12 Sep 2023 13:01 #280537 by tommylight
Feeding on worms? New age "healthy living"? :)
12 Sep 2023 14:05 #280546 by Aciera
Insect protein is the new thing but we are really getting off topic. :)
12 Sep 2023 15:58 #280565 by krigby
Replied by krigby on topic Repositioning the toolpath
I did a G54 and there was no change. Do I need to do a G10 L1 X<some value> Z<some value> first?
12 Sep 2023 16:12 #280566 by Aciera
'G54' will only call up the offset values. So yes, you will have to set the offset to something other than zero first to see an effect.
If you are using 'Axis' gui you can use the 'Touch off' button to set the offset to the current position but if certainly makes sense to learn to use the underlying gcode (ie g10).
Time to create page: 0.098 seconds
