Servo enable signal
- acourtjester
- Thank you received: 29
13 Sep 2023 17:13 #280649
by acourtjester
Servo enable signal was created by acourtjester
HiI am in the process of upgrading my CNC table to Clearpath Servos I am using a Mesa 7I76E board with Linuxcnc software for the controller. The board shows connecters for each axis outputs with the pins labeled. Each connecter has ground and +5 volt pins which I assume is for the enable for the axis servo signal.The question I have is the enable signal remove when the power button on the screen off/out.Or is there another signal used to enable/dis-able the servos Thanks for your timeTom
- acourtjester
13 Sep 2023 17:26 #280652
by acourtjester
Replied by acourtjester on topic Servo enable signal
I have since been told to use the field 24 volts to enable the servos.
But the question about the signal for enable on/off is still there.
- Thank you received: 5308
13 Sep 2023 17:41 #280654
Replied by PCW on topic Servo enable signal
The behaviour of the enable output signal is dependent on how is connected in the hal file
Typically it would be connected to say joint.0.amp-enable-out which will go false when
power off or estop are true
- acourtjester
13 Sep 2023 18:23 #280664
by acourtjester
thanks for the reply
have fun
Tom
have fun
Tom
Time to create page: 0.083 seconds
