Error starting LinuxCNC sim axis
  • NTULINUX
  • NTULINUX's Avatar Topic Author
  • Premium Member
  • Premium Member
14 Sep 2023 22:53 #280794 by NTULINUX
Error starting LinuxCNC sim axis was created by NTULINUX
Hi, I was just trying LinuxCNC out again on Gentoo and discovered a problem both with the 2.9 and master branches:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre1
Machine configuration directory is '/home/ntu/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
INIFILE=/home/ntu/linuxcnc/configs/sim.axis/axis.ini
VERSION=1.1
PARAMETER_FILE=sim.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(lib): /usr/share/linuxcnc/hallib/check_xyz_constraints.hal
Found file(REL): ./cooling.hal
Debug file information:
Note: Using POSIX realtime
count= and names= are mutually exclusive
and2: rtapi_app_main: Invalid argument (-22)
./cooling.hal:2: waitpid failed /usr/bin/rtapi_app and2
./cooling.hal:2: /usr/bin/rtapi_app exited without becoming ready
./cooling.hal:2: insmod for and2 failed, returned -1
4401
Stopping realtime threads
Unloading hal components
and2: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
Any ideas? Thank you!!
  • NTULINUX
  • Premium Member
  • Premium Member
14 Sep 2023 22:55 - 14 Sep 2023 22:56 #280795 by NTULINUX
Replied by NTULINUX on topic Error starting LinuxCNC sim axis
sim.axis -> "axis" fails however, "axis_9axis" loads just fine.. Funny how the more complicated one works just fine, heh!
axis_mm also fails.
Last edit: 14 Sep 2023 22:56 by NTULINUX. Reason: more info
15 Sep 2023 06:37 - 15 Sep 2023 06:38 #280811 by Aciera
Replied by Aciera on topic Error starting LinuxCNC sim axis
Could you try replacing the contents of 'cooling.hal' with this (I changed component count to names):
# Fake the existence of coolant options
loadrt and2 names=and2_cool
addf and2_cool servo-thread
net flood iocontrol.0.coolant-flood => and2_cool.in0
net mist iocontrol.0.coolant-mist => and2_cool.in1
Last edit: 15 Sep 2023 06:38 by Aciera.
15 Sep 2023 12:31 #280839 by tommylight
Replied by tommylight on topic Error starting LinuxCNC sim axis
First line says it is using both count and names
Last line says the AND component failed because of first line issue while adding it with loadrt.
15 Sep 2023 15:01 #280853 by Aciera
Yes, the strange thing is that if I add 'cooling.hal' to 'axis.ini' (as it is done in the current source) to a march build of master then it works just fine. So I'm not sure what else changed.
17 Sep 2023 08:26 #280986 by Aciera
Just built current master and I cannot reproduce this error.
  • NTULINUX
  • Premium Member
  • Premium Member
22 Oct 2023 01:40 #283475 by NTULINUX
Yes I think it's fixed now :)
