Memory requirements for very large gcode
- mariusl
19 Sep 2023 16:45 #281173
by mariusl
Regards
Marius
www.bluearccnc.com
Memory requirements for very large gcode was created by mariusl
Hi
What is the recommended memory required to run very large gcode files?
I am loading a file that is 6.6Mb and it takes several minutes to load.
I have 2Gb of Ram
I have 2Gb of Ram
Regards
Marius
www.bluearccnc.com
- Thank you received: 7461
19 Sep 2023 17:16 #281175
Replied by tommylight on topic Memory requirements for very large gcode
A while back we had a venture into that question, forgot what the size was, but i think it was over 50MB, i could load it easily on a monstrosity with 32GB of very fast (at that time) RAM and 8 cores.
All that is pretty much useless for you, and the only advice i can give you is get at least 8GB of RAM to work comfortably.
Linux is very good at managing memory, but there is so much stuff now in it to make it user friendly and look good that usually when all is said and done, 4GB is usable if you do not open a lot of programs at the same time, 8GB is comfortable for normal use, 16GB is probably enough for everything, except video editing and 3D modeling and rendering.
- mariusl
19 Sep 2023 17:32 #281178
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Memory requirements for very large gcode
Nothing else is open. Only Linuxcnc. I don't encourage users to run anything but the machine on the PC
I will upgrade to 8Gb and see how it goes.
Regards
Marius
www.bluearccnc.com
- zz912
- Thank you received: 98
19 Sep 2023 17:51 #281179
by zz912
Replied by zz912 on topic Memory requirements for very large gcode
This is solution in Gmoccapy:
linuxcnc.org/docs/2.9/html/gui/gmoccapy.html#_preview_control
The following user(s) said Thank You: mariusl
Time to create page: 0.082 seconds
