Trouble with Z axis/touch plate calibration
3 years 1 month ago #281205 by Sray69
So I am trying to calibrate my Z axis and touch plate but am struggling with the numbers. I seem to have two issues that may be separate or may be the same, I am not sure.
My first issue is the touch plate offset setting. Lets say my touch plate is .5" thick. I input .5" into the 100.ngc file. I then calibrate the Z axis by clicking the Touch Off button. If  I then input the command G90 G1 Z0.0 F10 and hit enter the end mill does not quite touch the spoilboard. Lets say that it is .005" from the spoil board. What is the correct way to fix this? Do I change the Z offset in the 100.ngc file by adding the .005" to the .5"? Or is this a Z axis calibration issue?
If it is Z axis calibration, then this brings me to my second issue. Lets say I have some plywood that is .713" thick (measured from the spoilboard to the top of the board). After I touch off the Z axis, if I input the command G90 G1 Z0.713 F10 and hit enter the end mill ends up .012 higher than the top of the board. If I run G90 G1 Z0.701 F10 the end mill will just touch the board. I understand the calibration formula ((distance commanded / distance moved) * old step scale = new step scale), but the touch plate issue is stumping me. I feel like I need to correct that first so that Z0 is Z0. But if the touch plate issue is the same issue as this then I am not sure what numbers I need to use in my calibration formula.
I hope this makes some sense. I would appreciate any help here.
3 years 1 month ago #281247 by Todd Zuercher
It is difficult to say exactly where your problem might be. The first step is to rule out that you don't have any lost motion issues do to backlash or missing steps. 2nd you need to confirm your axis calibration so your movement distances are correct. Then and only then are you ready to calibrate your probe touch plate. (This is the way I would approach it.)
The following user(s) said Thank You: Sray69
3 years 1 month ago - 3 years 1 month ago #281257 by Sray69
Thanks Todd for the help.
Lets assume that I do not have any lost motion or missed steps (although I would like to know exactly how to check this). I am fairly positive that it is calibration issue as I did a quick and not so accurate calibration when I first set the machine up. I was expecting/planning to do a more accurate calibration once I worked out most of the bugs and got the machine broke-in.
I just finished calibrating the Z-axis. I am within about .0005"-.001" tolerance. I think for wood applications that is acceptable. Now I need to figure out the touch plate. Once I get the touch plate thickness working correctly, then Z0.0 should be just touching the spoilboard (provided I have the calibration correct)?
I decided this morning to swap out my touch plate for a more accurate piece of aluminum because the touch plate I was using is a cheap one that has too much variance for me. After changing the touch plate and the offset (thickness) in the 100.ngc file I did a touch off and then ran Z0.0 and it stopped .8035" (which is the difference between the old touch plate and the new) above the spoilboard. So from what I can tell, changing the offset in 100.ngc file does not appear to do anything. So where do I actually put the offset (touch plate thickness) value for the touch plate?
Here is my 100.ngc file. My new touch plate is 1.572" thick. See the bolded section.
<pre> o100 sub G20 ( Set current Z position to 0 so that we will always be moving down ) G10 L20 P0 Z0 ( Probe to Z-.5 at F2 [Uses machine units, I work in inch, this is meant to be slow!] ) G38.2 Z-.25 f2 [b]( Set Z0 at point where probe triggers with offset of +1.004 [this is the thickness of my touch plate. You must adjust this for your plate / setup] ) (G10 L20 = Set Coordinate System // P - coordinate system 0-9 0 = Not active) G10 L20 P1 Z1.572[/b] ( Rapid up to Z.5 above the material ) (G10 L20 P1) (Use machine coordinates) G90 G53 G0 (Incremental mode) G91 (Rapid Z up 1 inches) G0 Z1 o100 endsub </pre>
Here is the Z axis section of my INI file.
# Generated by PNCconf at Fri Mar  3 16:12:30 2023 # Using LinuxCNC version:  Master (2.9) # If you make changes to this file, they will be # overwritten when you run PNCconf again [EMC] MACHINE = lcnc DEBUG = 0 VERSION = 1.1 [DISPLAY] DISPLAY = gmoccapy EMBED_TAB_NAME = Center_panel EMBED_TAB_LOCATION = ntb_preview EMBED_TAB_COMMAND = gladevcp -c gladevcp  -H gvcp_call_list.hal -x {XID} gvcp-panel.ui POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000 MAX_SPINDLE_OVERRIDE = 1.000000 MIN_SPINDLE_OVERRIDE = 0.500000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/shawn/linuxcnc/nc_files INCREMENTS = 20in 10in 1in .5in .1in .05in .01in .005in .001in .0005in .0001in POSITION_FEEDBACK = ACTUAL # Jog Speed - Also sets Jog Speed in LCNC Axis Manual Control Screen only if lower than MAX_LINEAR_VELOCITY. Otherwise MAX_LINEAR_VELOCITY sets this value. # DEFAULT_LINEAR_VELOCITY = 2.00000 # Sets the Jog Speed/Max Velocity in LCNC Axis Manual Control Screen # MAX_LINEAR_VELOCITY = 2.00000 MIN_LINEAR_VELOCITY = 0.016670 DEFAULT_ANGULAR_VELOCITY = 12.000000 MAX_ANGULAR_VELOCITY = 180.000000 MIN_ANGULAR_VELOCITY = 1.6666671 EDITOR = gedit GEOMETRY = xyz CYCLE_TIME = 100 [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script PROGRAM_EXTENSION = .ngc,.NGC,.nc,.NC,.txt,.tap Gcode file png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var SUBROUTINE_PATH = macros [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 SERVO_PERIOD = 2000000 [HMOT] # **** This is for info only **** CARD0=hm2_7i76e.0 [HAL] HALUI = halui HALFILE = lcnc.hal HALFILE = custom.hal POSTGUI_HALFILE = custom_postgui.hal SHUTDOWN = shutdown.hal [HALUI] # MDI_COMMAND=o100 call [KINS] JOINTS = 4 KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH [TRAJ] COORDINATES =  XYYZ LINEAR_UNITS = inch ANGULAR_UNITS = degree DEFAULT_LINEAR_VELOCITY = 0.33 MAX_LINEAR_VELOCITY = 3.33 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl TOOL_CHANGE_QUILL_UP = 1 [MACROS] MACRO = touch_plate_z #****************************************** [AXIS_X] MAX_VELOCITY = 3.3333333333333335 MAX_ACCELERATION = 90.0 MIN_LIMIT = -0.001 MAX_LIMIT = 44.761 [JOINT_0] TYPE = LINEAR HOME = 0.2 FERROR = 0.5 MIN_FERROR = 0.05 MAX_VELOCITY = 3.3333333333333335 MAX_ACCELERATION = 90 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 4.17 STEPGEN_MAXACCEL = 112.5 P = 500 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 8000 DIRHOLD    = 5000 STEPLEN    = 5000 STEPSPACE  = 5000 STEP_SCALE = 10170.17 MIN_LIMIT = -0.001 MAX_LIMIT = 44.761 # Distance traveled off limit switch once switch is triggered HOME_OFFSET = -0.100000 HOME_SEARCH_VEL = -0.833333 HOME_LATCH_VEL = 0.033333 # Speed from HOME_OFFSET to final HOME location HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 1 #****************************************** #****************************************** [AXIS_Y] MAX_VELOCITY = 3.3333333333333335 MAX_ACCELERATION = 90.0 MIN_LIMIT = -0.001 MAX_LIMIT = 49.851 [JOINT_1] TYPE = LINEAR HOME = 2.703 FERROR = 0.5 MIN_FERROR = 0.05 MAX_VELOCITY = 3.3333333333333335 MAX_ACCELERATION = 90 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 4.17 STEPGEN_MAXACCEL = 112.5 P = 500 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 8000 DIRHOLD    = 5000 STEPLEN    = 5000 STEPSPACE  = 5000 STEP_SCALE = -10159.9564 MIN_LIMIT = -0.001 MAX_LIMIT = 49.851 HOME_OFFSET = 0.100000 HOME_SEARCH_VEL = -0.933333 HOME_LATCH_VEL = 0.333333 HOME_FINAL_VEL = 0.900000 HOME_IGNORE_LIMITS = YES HOME_USE_INDEX = NO HOME_SEQUENCE = -2 [JOINT_2] TYPE = LINEAR HOME = 2.703 FERROR = 0.5 MIN_FERROR = 0.05 MAX_VELOCITY = 3.3333333333333335 MAX_ACCELERATION = 90 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 4.17 STEPGEN_MAXACCEL = 112.5 P = 500 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 8000 DIRHOLD    = 5000 STEPLEN    = 5000 STEPSPACE  = 5000 STEP_SCALE = -10159.9564 MIN_LIMIT = -0.001 MAX_LIMIT = 49.851 HOME_OFFSET = 0.100000 HOME_SEARCH_VEL = -0.933333 HOME_LATCH_VEL = 0.333333 HOME_FINAL_VEL = 0.900000 HOME_IGNORE_LIMITS = YES HOME_USE_INDEX = NO HOME_SEQUENCE = -2 #****************************************** #****************************************** [AXIS_Z] MAX_VELOCITY = 0.5 MAX_ACCELERATION = 50.0 MIN_LIMIT = -5.251 MAX_LIMIT = 0.001 [JOINT_3] TYPE = LINEAR HOME = -0.2 FERROR = 0.5 MIN_FERROR = 0.05 MAX_VELOCITY = 0.5 MAX_ACCELERATION = 50.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 0.62 STEPGEN_MAXACCEL = 62.5 P = 500 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 8000 DIRHOLD    = 5000 STEPLEN    = 2500 STEPSPACE  = 2500 STEP_SCALE = 10304.26 MIN_LIMIT = -5.251 MAX_LIMIT = 0.001 HOME_OFFSET = -0.100000 HOME_SEARCH_VEL = 0.500000 HOME_LATCH_VEL = -0.033333 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 0 #******************************************
Here is my HAL file in case it helps.
# Generated by PNCconf at Fri Mar  3 16:12:30 2023 # Using LinuxCNC version:  Master (2.9) # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS loadrt hostmot2 loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=0 num_stepgens=4 sserial_port_0=00xxxx"  setp    hm2_7i76e.0.watchdog.timeout_ns 5000000 loadusr -W hal_input -KRAL Logitech Gamepad F310 loadrt pid names=pid.x,pid.y1,pid.y2,pid.z,pid.s loadrt mux16 names=jogspeed addf hm2_7i76e.0.read          servo-thread addf motion-command-handler   servo-thread addf motion-controller        servo-thread addf pid.x.do-pid-calcs       servo-thread addf pid.y1.do-pid-calcs       servo-thread addf pid.y2.do-pid-calcs       servo-thread addf pid.z.do-pid-calcs       servo-thread addf pid.s.do-pid-calcs       servo-thread addf jogspeed                 servo-thread addf hm2_7i76e.0.write         servo-thread setp hm2_7i76e.0.dpll.01.timer-us -50 setp hm2_7i76e.0.stepgen.timer-number 1 # external output signals # --- ESTOP-OUT --- net estop-out  =>     hm2_7i76e.0.7i76.0.0.output-00 # --- ROUTER-ON --- net coolant-mist   =>     hm2_7i76e.0.7i76.0.0.output-08 # --- DUST-COLLECTOR-ON net coolant-flood   =>  hm2_7i76e.0.7i76.0.0.output-01 # external input signals # --- ESTOP-EXT --- net estop-ext     <=  hm2_7i76e.0.7i76.0.0.input-04 # --- BOTH-HOME-X --- net both-home-x     <=  hm2_7i76e.0.7i76.0.0.input-05-not # --- HOME-Y1 --- net home-y1     <=  hm2_7i76e.0.7i76.0.0.input-06-not # --- BOTH-HOME-Y2 --- net both-home-y2     <=  hm2_7i76e.0.7i76.0.0.input-07-not # --- BOTH-HOME-Z --- net both-home-z     <=  hm2_7i76e.0.7i76.0.0.input-08-not #******************* #  AXIS X JOINT 0 #******************* setp   pid.x.Pgain     [JOINT_0]P setp   pid.x.Igain     [JOINT_0]I setp   pid.x.Dgain     [JOINT_0]D setp   pid.x.bias      [JOINT_0]BIAS setp   pid.x.FF0       [JOINT_0]FF0 setp   pid.x.FF1       [JOINT_0]FF1 setp   pid.x.FF2       [JOINT_0]FF2 setp   pid.x.deadband  [JOINT_0]DEADBAND setp   pid.x.maxoutput [JOINT_0]MAX_OUTPUT setp   pid.x.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.x.maxerror 0.000500 net x-index-enable  <=> pid.x.index-enable net x-enable        =>  pid.x.enable net x-pos-cmd       =>  pid.x.command net x-pos-fb        =>  pid.x.feedback net x-output        <=  pid.x.output # Step Gen signals/setup setp   hm2_7i76e.0.stepgen.00.dirsetup        [JOINT_0]DIRSETUP setp   hm2_7i76e.0.stepgen.00.dirhold         [JOINT_0]DIRHOLD setp   hm2_7i76e.0.stepgen.00.steplen         [JOINT_0]STEPLEN setp   hm2_7i76e.0.stepgen.00.stepspace       [JOINT_0]STEPSPACE setp   hm2_7i76e.0.stepgen.00.position-scale  [JOINT_0]STEP_SCALE setp   hm2_7i76e.0.stepgen.00.step_type        0 setp   hm2_7i76e.0.stepgen.00.control-type     1 setp   hm2_7i76e.0.stepgen.00.maxaccel         [JOINT_0]STEPGEN_MAXACCEL setp   hm2_7i76e.0.stepgen.00.maxvel           [JOINT_0]STEPGEN_MAXVEL # ---closedloop stepper signals--- net x-pos-cmd    <= joint.0.motor-pos-cmd net x-vel-cmd    <= joint.0.vel-cmd net x-output     => hm2_7i76e.0.stepgen.00.velocity-cmd net x-pos-fb     <= hm2_7i76e.0.stepgen.00.position-fb net x-pos-fb     => joint.0.motor-pos-fb net x-enable     <= joint.0.amp-enable-out net x-enable     => hm2_7i76e.0.stepgen.00.enable # ---setup home / limit switch signals--- net both-home-x     =>  joint.0.home-sw-in net both-home-x     =>  joint.0.neg-lim-sw-in net both-home-x     =>  joint.0.pos-lim-sw-in #******************* #  AXIS Y1 JOINT 1 #******************* setp   pid.y1.Pgain     [JOINT_1]P setp   pid.y1.Igain     [JOINT_1]I setp   pid.y1.Dgain     [JOINT_1]D setp   pid.y1.bias      [JOINT_1]BIAS setp   pid.y1.FF0       [JOINT_1]FF0 setp   pid.y1.FF1       [JOINT_1]FF1 setp   pid.y1.FF2       [JOINT_1]FF2 setp   pid.y1.deadband  [JOINT_1]DEADBAND setp   pid.y1.maxoutput [JOINT_1]MAX_OUTPUT setp   pid.y1.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.y1.maxerror 0.000500 net y1-index-enable  <=> pid.y1.index-enable net y1-enable        =>  pid.y1.enable net y1-pos-cmd       =>  pid.y1.command net y1-pos-fb        =>  pid.y1.feedback net y1-output        <=  pid.y1.output # Step Gen signals/setup setp   hm2_7i76e.0.stepgen.01.dirsetup        [JOINT_1]DIRSETUP setp   hm2_7i76e.0.stepgen.01.dirhold         [JOINT_1]DIRHOLD setp   hm2_7i76e.0.stepgen.01.steplen         [JOINT_1]STEPLEN setp   hm2_7i76e.0.stepgen.01.stepspace       [JOINT_1]STEPSPACE setp   hm2_7i76e.0.stepgen.01.position-scale  [JOINT_1]STEP_SCALE setp   hm2_7i76e.0.stepgen.01.step_type        0 setp   hm2_7i76e.0.stepgen.01.control-type     1 setp   hm2_7i76e.0.stepgen.01.maxaccel         [JOINT_1]STEPGEN_MAXACCEL setp   hm2_7i76e.0.stepgen.01.maxvel           [JOINT_1]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y1-pos-cmd    <= joint.1.motor-pos-cmd net y1-vel-cmd    <= joint.1.vel-cmd net y1-output     => hm2_7i76e.0.stepgen.01.velocity-cmd net y1-pos-fb     <= hm2_7i76e.0.stepgen.01.position-fb net y1-pos-fb     => joint.1.motor-pos-fb net y1-enable     <= joint.1.amp-enable-out net y1-enable     => hm2_7i76e.0.stepgen.01.enable # ---setup home / limit switch signals--- net home-y1     =>  joint.1.home-sw-in net home-y1     =>  joint.1.neg-lim-sw-in # net home-y1     =>  joint.2.pos-lim-sw-in #******************* #  Tandem AXIS Y2 JOINT 2 #******************* setp   pid.y2.Pgain     [JOINT_2]P setp   pid.y2.Igain     [JOINT_2]I setp   pid.y2.Dgain     [JOINT_2]D setp   pid.y2.bias      [JOINT_2]BIAS setp   pid.y2.FF0       [JOINT_2]FF0 setp   pid.y2.FF1       [JOINT_2]FF1 setp   pid.y2.FF2       [JOINT_2]FF2 setp   pid.y2.deadband  [JOINT_2]DEADBAND setp   pid.y2.maxoutput [JOINT_2]MAX_OUTPUT setp   pid.y2.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.y2.maxerror 0.000500 net y2-index-enable  <=> pid.y2.index-enable net y2-enable        =>  pid.y2.enable net y2-pos-cmd       =>  pid.y2.command net y2-pos-fb        =>  pid.y2.feedback net y2-output        <=  pid.y2.output # Step Gen signals/setup for tandem axis setp   hm2_7i76e.0.stepgen.02.dirsetup        [JOINT_2]DIRSETUP setp   hm2_7i76e.0.stepgen.02.dirhold         [JOINT_2]DIRHOLD setp   hm2_7i76e.0.stepgen.02.steplen         [JOINT_2]STEPLEN setp   hm2_7i76e.0.stepgen.02.stepspace       [JOINT_2]STEPSPACE setp   hm2_7i76e.0.stepgen.02.position-scale  [JOINT_2]STEP_SCALE setp   hm2_7i76e.0.stepgen.02.step_type        0 setp   hm2_7i76e.0.stepgen.02.control-type     1 setp   hm2_7i76e.0.stepgen.02.maxaccel         [JOINT_2]STEPGEN_MAXACCEL setp   hm2_7i76e.0.stepgen.02.maxvel           [JOINT_2]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y2-pos-cmd    <= joint.2.motor-pos-cmd net y2-vel-cmd    <= joint.2.vel-cmd net y2-output     => hm2_7i76e.0.stepgen.02.velocity-cmd net y2-pos-fb     <= hm2_7i76e.0.stepgen.02.position-fb net y2-pos-fb     => joint.2.motor-pos-fb net y2-enable     <= joint.2.amp-enable-out net y2-enable     => hm2_7i76e.0.stepgen.02.enable # ---setup home / limit switch signals--- net both-home-y2     =>  joint.2.home-sw-in net both-home-y2     =>  joint.2.neg-lim-sw-in net both-home-y2     =>  joint.2.pos-lim-sw-in #******************* #  AXIS Z JOINT 3 #******************* setp   pid.z.Pgain     [JOINT_3]P setp   pid.z.Igain     [JOINT_3]I setp   pid.z.Dgain     [JOINT_3]D setp   pid.z.bias      [JOINT_3]BIAS setp   pid.z.FF0       [JOINT_3]FF0 setp   pid.z.FF1       [JOINT_3]FF1 setp   pid.z.FF2       [JOINT_3]FF2 setp   pid.z.deadband  [JOINT_3]DEADBAND setp   pid.z.maxoutput [JOINT_3]MAX_OUTPUT setp   pid.z.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.z.maxerror 0.000500 net z-index-enable  <=> pid.z.index-enable net z-enable        =>  pid.z.enable net z-pos-cmd       =>  pid.z.command net z-pos-fb        =>  pid.z.feedback net z-output        <=  pid.z.output # Step Gen signals/setup setp   hm2_7i76e.0.stepgen.03.dirsetup        [JOINT_3]DIRSETUP setp   hm2_7i76e.0.stepgen.03.dirhold         [JOINT_3]DIRHOLD setp   hm2_7i76e.0.stepgen.03.steplen         [JOINT_3]STEPLEN setp   hm2_7i76e.0.stepgen.03.stepspace       [JOINT_3]STEPSPACE setp   hm2_7i76e.0.stepgen.03.position-scale  [JOINT_3]STEP_SCALE setp   hm2_7i76e.0.stepgen.03.step_type        0 setp   hm2_7i76e.0.stepgen.03.control-type     1 setp   hm2_7i76e.0.stepgen.03.maxaccel         [JOINT_3]STEPGEN_MAXACCEL setp   hm2_7i76e.0.stepgen.03.maxvel           [JOINT_3]STEPGEN_MAXVEL # ---closedloop stepper signals--- net z-pos-cmd    <= joint.3.motor-pos-cmd net z-vel-cmd    <= joint.3.vel-cmd net z-output     => hm2_7i76e.0.stepgen.03.velocity-cmd net z-pos-fb     <= hm2_7i76e.0.stepgen.03.position-fb net z-pos-fb     => joint.3.motor-pos-fb net z-enable     <= joint.3.amp-enable-out net z-enable     => hm2_7i76e.0.stepgen.03.enable # ---setup home / limit switch signals--- net both-home-z     =>  joint.3.home-sw-in net both-home-z     =>  joint.3.neg-lim-sw-in net both-home-z     =>  joint.3.pos-lim-sw-in #****************************** # connect miscellaneous signals #****************************** #  ---coolant signals--- net coolant-mist      <=  iocontrol.0.coolant-mist net coolant-flood     <=  iocontrol.0.coolant-flood #  ---probe signal--- net probe-in     =>  motion.probe-input #limits debounce to stop false triggers loadrt debounce cfg=1 #change to the number you want setp debounce.0.delay 100 #this sets the delay 100 iterations of the servo-thread addf debounce.0 servo-thread net deb-probe-in debounce.0.0.in <= hm2_7i76e.0.7i76.0.0.input-09-not net probe-in debounce.0.0.out net probe-in => motion.probe-input #  ---motion control signals--- net in-position               <=  motion.in-position net machine-is-enabled        <=  motion.motion-enabled #  ---digital in / out signals--- #  ---estop signals--- net estop-out     <=  iocontrol.0.user-enable-out net estop-ext     =>  iocontrol.0.emc-enable-in #  ---toolchange signals for custom tool changer--- net tool-number             <=  iocontrol.0.tool-prep-number net tool-change-request     <=  iocontrol.0.tool-change net tool-change-confirmed   =>  iocontrol.0.tool-changed net tool-prepare-request    <=  iocontrol.0.tool-prepare net tool-prepare-confirmed  =>  iocontrol.0.tool-prepared
Last edit: 3 years 1 month ago by Sray69.
3 years 1 month ago #281259 by tommylight
The following user(s) said Thank You: Todd Zuercher
3 years 1 month ago #281274 by Sray69
Alright I think I may have found my answer to my touch plate problem. I could not figure out why changing the touch plate offset in the 100.ngc file made no difference. I realized I may have been changing the wrong file. In my INI file the following section points to a different file.
I found that file in the Macros folder. Here is the file.
o<touch_plate_z> sub #<PlateThickness> =      .739   ( Subtract .018 from actual plate thickness! Thickness of your touch plate when proving in the Z orientation, this is used to re-calculate your new zero after touching off ) #<FastProbe> =            5     ( This is the probe speed used for your initial search, this should be a slow value to avoid damaging your tool, but doesn not need to "crawl"  ) #<SlowProbe> =             2     ( This is the probe speed for the final search, this should be a very slow value to improve the accuracy of the probing ) #<ZProbeRange> =          -.50   ( This is the distance the probe will travel on its initial search before erroring out, should be a negative value ) #<ProbeLift> =             0.10  ( This is the distance the probe will lift off the touch plate prior to starting the second search ) #<ProbeRetract> =         1.00   ( This is the distance the probe will lift from the touch plate after succesful probing to allow for removal of the plate ) ( Set current Z position to 0 so that we will always be moving down ) G10 L20 P0 Z0 ( Probe quickly for initial contact ) G91 F[#<FastProbe>] G38.2 Z[#<ZProbeRange>] ( Move off plate for slow search ) F[#<SlowProbe>] G1 Z[#<Probelift>] ( Pause for 0.5 Sec ) G4 P0.5 ( Slow probe search ) g38.2 Z[-2 * #<ProbeLift>] ( Move up to set new zero ) G1 Z[#<ProbeRetract>] F[#<FastProbe>] ( Set Z0 at point where probe triggers with offset of plate thickness) G10 L20 P0 Z[#<ProbeRetract> + #<PlateThickness>] o<touch_plate_z> endsub M2
I have a question about the first section "#<PlateThickness>". In the comments on that line it says "Subtract .018 from actual plate thickness!". I am wondering if that is why I always had to add .015-.020 to the thickness of the board in order for it to cut all the way through?
Will not know until tomorrow if this will fix my touch plate issue but it is looking promising.
3 years 1 month ago #281327 by Todd Zuercher
I do not know where the "Subtract .018 from actual plate thickness!" comment comes from. I've never used these probing routines. The only Linuxcnc machines I have using a tool touch off system, I wrote the routines myself and it has been a long time since I've revisited them. I do know that I only used the measured thickness of my touch off plate as a rough starting point, then fine tuned the value until I got consistent good results. I do not know what the difference between my measured and probed plate thickness was, but I am very doubtful it was as much as 0.018", probably closer to a tenth of that.
Time to create page: 0.191 seconds
