ATC: carousel.comp with Servo drive
- jimwhiting
- Thank you received: 6
01 Sep 2024 17:55 #309162
by jimwhiting
Replied by jimwhiting on topic ATC: carousel.comp with Servo drive
Thanks,
I actually managed to find the correct setting (SDO 0x2222 - set to 200) to limit the initial jolt from the servo... so it looks like I can drive directly. Just getting some tuning done and I will post up the configs.
-Jim.
-Jim.
- jimwhiting
01 Sep 2024 20:42 #309169
by jimwhiting
Just to follow this up, I have it working great for small movements... but the moment I try and index to a pocket further away it error's my drive out (1b0 - Bus dithering).
Looking into the mode further... it is using CSP mode, which from the docs expects to be updated periodically with a location from a "movement planner". So I think I need to use Position Profile instead - which would allow a final position to be put in the target position register and then the movement profile (accel/velocity/decell etc) would be used from the drives settings.
So I will be hacking around a cia402 module to see if I can test this.
- COFHAL
- Thank you received: 62
02 Sep 2024 01:38 #309181
by COFHAL
Replied by COFHAL on topic ATC: carousel.comp with Servo drive
I use the carousell component with a stepper motor in step-dir mode without any problem. So I think there is no problem using a servo motor.
- Abdulkareem
01 Dec 2024 10:17 #315719
by Abdulkareem
Replied by Abdulkareem on topic ATC: carousel.comp with Servo drive
hello
could you provide the hal connection for the stepper step/dir connection to the carousel component , i am using mesa 7i96s board
Time to create page: 0.071 seconds
