6th axis in XYZAC-trt
- akg1904
- Thank you received: 4
22 Sep 2023 11:00 #281363
by akg1904
6th axis in XYZAC-trt was created by akg1904
I was able to successfully integrate 5-Axis machine using xyzac-trt Kinematics.
Now I want to add one more axis in same kinematics, I am able to add but for some reason I am not able to run the motor using jog mode/MDI in AXIS-gui.
Has anyone integrated 6-axis in their xyzac-trt Kinematics?
Please help me figure out what i am missing.
I have attached my INI and Hal file below
Regards
Abhishek
Regards
Abhishek
- Thank you received: 2163
22 Sep 2023 12:49 - 22 Sep 2023 13:14 #281369
Does the DRO display change?
Does the value 'joint.5.motor-pos-cmd' change?
[edit]
This is the most likely problem:
in the [KINS] section of your ini file change:
KINEMATICS = xyzac-trt-kins sparm=identityfirst
To:
KINEMATICS = xyzac-trt-kins sparm=identityfirst coordinates=xyzacu
Replied by Aciera on topic 6th axis in XYZAC-trt
[edit]
To:
Last edit: 22 Sep 2023 13:14 by Aciera.
The following user(s) said Thank You: akg1904
- akg1904
22 Sep 2023 14:12 #281380
by akg1904
Replied by akg1904 on topic 6th axis in XYZAC-trt
Hi Aciera,
Thank you for the help..
it didn't clicked at all that the motor was not running due to such silly thing.
there is one more question which is really troubling me...
I was doing some experiment with ethercat, as I was trying to run my servo drive using CSV mode instead of CSP mode but I didn't succeed.
If you have any idea or example of CSV mode in Ethercat can you please share it with me.
Regards
Abhishek
Regards
Abhishek
22 Sep 2023 14:47 #281386
I'm sorry I have no experience with Ethercat at all. So maybe open a new thread in the ethercat section with that question.
Time to create page: 0.202 seconds
