Sherline chucker lathe threading is not working correctly
- Brassdream2014
01 Oct 2023 12:30 #281979
by Brassdream2014
Sherline chucker lathe threading is not working correctly was created by Brassdream2014
I purchased a Chucker lathe from Sherline three months ago. As I have worked to get the machine up and working I have been building a profile for my business. I tried to get the lathe to do 40 TPI but it is producing what looks like 80 tpi. It has 10mm ballscrews with 2mm pitch. I had problem with distance being correct until Sherline told me to set the revolutions per inch at 6.35. This got the cutting proportion working correctly but the threading is just plain off. Here is sample of my code for threading.
G90
S100 M3
G1 X 0.419 f 2.0
G1 Z 2.4 f 6.0
G33 Z 2.725 K0.025
G0 X 0.390
G0 Z 2.4
M2
Not sure what is going on. Something is wrong with the numbers in the stepconf. All help is appreciated.
G90
S100 M3
G1 X 0.419 f 2.0
G1 Z 2.4 f 6.0
G33 Z 2.725 K0.025
G0 X 0.390
G0 Z 2.4
M2
- Thank you received: 2173
01 Oct 2023 16:29 #281995
Replied by cmorley on topic Sherline chucker lathe threading is not working correctly
please post your config files
- Brassdream2014
02 Oct 2023 09:54 #282056
by Brassdream2014
Replied by Brassdream2014 on topic Sherline chucker lathe threading is not working correctly
- Brassdream2014
03 Oct 2023 23:39 #282225
by Brassdream2014
I checked and compared the Hal files to ones from my sherline 4000 which threaded correctly. There was information missing in the Chucker hal file.
I built a new profile and had encoder information included. I now get a defined thread but the problem is I changed the K parameter from 0.025 to 0.050 and it looks like 40 tpi. Which should not be. that should be 20 TPI.
not sure what is going on.
Time to create page: 0.095 seconds
