Ohmic sensing with Mesa Thcad2
- mariusl
05 Oct 2023 12:48 #282360
by mariusl
Regards
Marius
www.bluearccnc.com
Ohmic sensing with Mesa Thcad2 was created by mariusl
It was mentioned that there is a special bit file for the 7i96S to use a second encoder channel if one wants to do ohmic sensing with a Thad2 and the 7i96S?
I looked at the ZIP file with all the support bit files but I a cannot decode the bit file names to tell me what to use? Anyone got some info please?
Regards
Marius
www.bluearccnc.com
- Thank you received: 5308
05 Oct 2023 13:46 #282363
Replied by PCW on topic Ohmic sensing with Mesa Thcad2
7i96s_dpl.bin is made for this kind of use
- mariusl
05 Oct 2023 14:12 #282366
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Ohmic sensing with Mesa Thcad2
Peter I get an "invalid bit file header" error if I try to load that bin file.
Regards
Marius
www.bluearccnc.com
05 Oct 2023 14:37 #282367
You may need to update your copy of mesaflash.
I get:
peter@peter-HP-EliteDesk-800-G1-USDT:~/bitfiles$ mesaflash --device 7i96s --addr 10.10.10.10 --write 7i96s_dpl.bin --reload
Checking file... OK
File type: Efinix bin file
FLASH memory sectors to write: 11, max sectors in area: 16
Erasing FLASH memory sectors starting from 0x100000...
|EEEEEEEEEEE
Programming FLASH memory sectors starting from 0x100000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
Verifying FLASH memory sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
I get:
Checking file... OK
|EEEEEEEEEEE
Checking file... OK
- mariusl
05 Oct 2023 15:09 - 05 Oct 2023 15:11 #282371
by mariusl
Regards
Marius
www.bluearccnc.com
My mesaflash is from Master branch. Can it be outdated?
My version is 3.4.0-pre1
Regards
Marius
www.bluearccnc.com
Last edit: 05 Oct 2023 15:11 by mariusl.
05 Oct 2023 15:18 #282372
Yes, that's pretty old:
peter@peter-HP-EliteDesk-800-G1-USDT:~/bitfiles$ mesaflash --version
Mesaflash version 3.4.8
The following user(s) said Thank You: mariusl
- mariusl
05 Oct 2023 15:29 #282373
by mariusl
Regards
Marius
www.bluearccnc.com
Oh ok. Didn't realize that. We should ask the gents to put the latest in master at least.
Do I have to download and compile?
Regards
Marius
www.bluearccnc.com
05 Oct 2023 15:37 #282374
Yes, I would download and re-compile
3.4.0 is about 2 years old
instructions at bottom of page:
github.com/LinuxCNC/mesaflash
- mariusl
05 Oct 2023 15:38 #282375
by mariusl
Regards
Marius
www.bluearccnc.com
That worked. Thanks Peter. I will just download and compile as a rule.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.169 seconds
