Mesa - 7i96S stepper channels
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
06 Oct 2023 13:54 #282439 by mariusl
Mesa - 7i96S stepper channels was created by mariusl
@PCW
Peter is it possible to run additional stepper channels on the P1 port of the 7i96S?  At most two more.
Regards
Marius
www.bluearccnc.com
06 Oct 2023 14:52 #282442 by tommylight
Replied by tommylight on topic Mesa - 7i96S stepper channels
I would venture a firm guess at yes you can, probably would need firmware flash, something like 7i96S_7i76 if such thing exists, but first, what does mesaflash return?
  • mariusl
  • Platinum Member
  • Platinum Member
06 Oct 2023 15:36 #282447 by mariusl
Replied by mariusl on topic Mesa - 7i96S stepper channels
The port is available and programmed for general IO but the standard firmware only allows for five stepper gens.
I don't have the Xilinx development software anymore otherwise I would have tried.
Regards
Marius
www.bluearccnc.com
06 Oct 2023 16:00 #282448 by PCW
Replied by PCW on topic Mesa - 7i96S stepper channels
Yes, several standard 7I96S configurations have additional step/dir channels
for example:
7i96s_5abobd.bin
Works with the standard "Mach 5 Axis BOB" to add 5 more step/dir channels
In addition these binfiles work with various Mesa daughtercards and add more step/dir channels:
7i96s_7i76d.bin
7i96s_7i78d.bin
7i96s_7i85sd.bin
7i96s_7i85dsdi.bin
  • mariusl
  • Platinum Member
  • Platinum Member
06 Oct 2023 16:14 #282449 by mariusl
I loaded the 7i96s_5abobd.bin file but I don't get the correct firmware option on PncConf for that.
Regards
Marius
www.bluearccnc.com
06 Oct 2023 17:15 #282452 by PCW
Yes, you would need to make a working 7I96S configuration
and manually add the additional  joints/axis
(mainly a copy/paste/rename exercise)
  • mariusl
  • Platinum Member
  • Platinum Member
08 Oct 2023 15:47 #282547 by mariusl
Ah thanks Peter. I will do than.
I suppose I should use the encoder on P1 then for Ohmic sensing with the THAD2 as I am already using the encoder on TB2/3 for the Plasma Arc Voltage with another THAD2?
Regards
Marius
www.bluearccnc.com
08 Oct 2023 16:39 - 08 Oct 2023 16:40 #282550 by PCW
Probably best to add the 5ABOB P1 option to a 7I96S plasma config
so you have the three TB2 RS-422 encoder inputs. I can probably do
this in the next day or so.
Last edit: 08 Oct 2023 16:40 by PCW.
The following user(s) said Thank You: mariusl
09 Oct 2023 16:37 #282631 by PCW
7i96s config with 5ABOB on P1 and 3 "A" only encoders
on TB2
File Name: 7i96s_5abobdpl.zip
File Size:286 KB
  • mariusl
  • Platinum Member
  • Platinum Member
09 Oct 2023 16:55 #282634 by mariusl
Awesome Peter. Thanks a lot. I will test tomorrow
Regards
Marius
www.bluearccnc.com
Time to create page: 0.396 seconds
