Error when compiling user module
- mariusl
19 Oct 2023 13:42 #283297
by mariusl
Regards
Marius
www.bluearccnc.com
Error when compiling user module was created by mariusl
I am trying to compile a user kinamatics module for a RIP environment using master branch.
If I use the template userkfuncs.c to test the compile, I get the error as well.
This happens for the RIP and the debs installation.
Any suggestions please?
Compiling realtime userkfuncs.c
Linking userkfuncs.so
/usr/bin/ld:userkfuncs.ver:2: syntax error in VERSION script
collect2: error: ld returned 1 exit status
make: *** [/usr/share/linuxcnc/Makefile.modinc:125: userkfuncs.so] Error 1This happens for the RIP and the debs installation.
Regards
Marius
www.bluearccnc.com
- Thank you received: 2163
19 Oct 2023 15:12 #283302
Replied by Aciera on topic Error when compiling user module
Can't help you there but as an alternative you could use the 'src/hal/components/millturn.comp' file as a template for your switchable kinematics which can then be installed like any component using 'halcompile'
The following user(s) said Thank You: mariusl
- mariusl
19 Oct 2023 15:47 #283304
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Error when compiling user module
Just came to that conclusion after I read your thread on the topic. I tested the comp template and it compiled just fine. We are busy switching over.
This has been a very frustrating journey with the kinematics.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.123 seconds
