High max jitter
- OneMyr
08 Nov 2023 12:58 - 08 Nov 2023 13:29 #284863
by OneMyr
High max jitter was created by OneMyr
Hello there,
actually i am having a high max jitter, i tried to run linuxcnc on my raspberry pi 4 and when i run the latency test i got values of servo thread of about 88972574 and base of 50056722 like in this image drive.google.com/file/d/1Dx10cUhac0YA6R9...sK/view?usp=drivesdk, and i don't know how to solve it, is it possible?
i tired with another build and the this was the values drive.google.com/file/d/1EH_aMwVQL3exWtA...7a/view?usp=drivesdk
thanks, and sorry if i miss something
Last edit: 08 Nov 2023 13:29 by OneMyr.
- Thank you received: 5308
08 Nov 2023 14:04 #284867
Replied by PCW on topic High max jitter
It looks like you are not using a real time kernel.
What does the command
uname a
report?
uname a
report?
- OneMyr
08 Nov 2023 14:47 #284871
by OneMyr
Replied by OneMyr on topic High max jitter
when i use the command it report this
Linux rpi 6.1.0-rpi6-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (2023-10-27) a
08 Nov 2023 15:12 #284874
OK, that's a real time kernel so the problem is elsewhere
Is force_turbo enabled in your config.txt file?
It may also be that a 25KHz base thread is too fast for the RPI
so running the base thread at a lower speed during the test
may improve the results.
latency-test --help
for how to do this
latency-test --help
for how to do this
- OneMyr
08 Nov 2023 16:56 #284881
by OneMyr
force_turbo isnt enable, but arm_boost is enable,
is that?
is that?
08 Nov 2023 18:06 #284887
I think you have to enable force_turbo or the RPI will change CPU clock speeds
while running, causing massive delays because the CPU is halted until the PLL
reaches the new frequency.
I would probably not use arm_boost until you have some CPU temperature data
Time to create page: 0.199 seconds
