Run From Here !
2 years 11 months ago #285020 by ClarkSavage
Replied by ClarkSavage on topic Run From Here !
Thanks again - Axis for me too. Must be something messed up somewhere then. Will keep playing and if I figure it out will post the solution.
Do appreciate the attempt and time spent.
2 years 10 months ago - 2 years 10 months ago #288292 by JohnR
Replied by JohnR on topic Run From Here !
Hi...
My first post but a long time and happy LInuxCNC user. Running Bookworm and LinuxCNC 2.9.1 and Axis on my home milling machine. I have the same problem. Not sure when it started, not often that I need to use the "run from here" function. Very interested in what solution you come up with. Cheers!
Last edit: 2 years 10 months ago by JohnR.
2 years 10 months ago #288305 by Aciera
Replied by Aciera on topic Run From Here !
'Run From Here' is broken in Version 2.9.1 and will be fixed in the next point release:
github.com/LinuxCNC/linuxcnc/issues/2771
The fix is simple enough:
github.com/LinuxCNC/linuxcnc/commit/a15c...509fdb837920aa7c8d2f
Note if you want to patch your installation yourself you would want to modify 'bin/axis.py'
The following user(s) said Thank You: Unlogic
2 years 10 months ago #288309 by JohnR
Many thanks for the prompt reply... much appreciated.
I'll check out the links but good to hear there is a fix in the pipeline and it's not me fumbling around in the weeds. Again, thanks!
