need postprocessor for Tormach 1100 series 3
- jeeves99
12 Nov 2023 17:06 #285182
by jeeves99
need postprocessor for Tormach 1100 series 3 was created by jeeves99
Available: Tormach 1100 series 3; Vectric's VCarve Pro running on Windows 10 machine.
Need: the linuxcnc postprocessor in simple text format for the Tormach machine so that I can edit it to be run from VCarve Pro.
I'm confused but I do have considerable programming experience.
Just the linuxcnc postprocessor in simple text format would do me fine.
Please help, if possible; otherwise, tell me.
Thanks, Sherril
Thanks, Sherril
- Thank you received: 4648
20 Nov 2023 11:28 #286020
Replied by andypugh on topic need postprocessor for Tormach 1100 series 3
Is there a generic LinuxCNC post?
For a mill LinuxCNC is almost entirely conventional, so a wide variety of posts are likely to work.
- Clive S
- Thank you received: 486
20 Nov 2023 18:02 #286071
by Clive S
Replied by Clive S on topic need postprocessor for Tormach 1100 series 3
There is a post in Aspire for linux called LinuxCNC_G64_Arcs_mm.pp
Time to create page: 0.099 seconds
