7i76E connection to Huanyang HY02D223B
  • gardenweazel
  • gardenweazel's Avatar Topic Author
  • Elite Member
  • Elite Member
13 Nov 2023 18:42 - 13 Nov 2023 18:45 #285296 by gardenweazel
7i76E connection to Huanyang HY02D223B was created by gardenweazel
Can anyone confirm these settings?
Huanyang HY02D223B 2.2kw using 220V(240V) US power.
I am getting a E.OC.A which equates to an over current error.
These are the settings from the VFD as it is now:
<pre>
Setting Value
PD000 0
PD001 1
PD002 1
PD003 200
PD004
PD005 400
PD006 2.5
PD007 0.5
PD008 220
PD009 15
PD010 8
PD011 120
PD012
PD013
PD014 12
PD015 15
PD016 12
PD017 15
PD018 12
PD019 15
PD020 12
PD021 15
PD022
PD023 1
PD024 1
PD025 0
PD026 0
PD027 0.5
PD028 0.5
PD029 0
PD030 0
PD031 2
PD032 5
PD033 150
PD034 0.5
PD035 to PD040 = RESERVED
PD041
PD042 5
PD043
PD044 1
PD045 5
PD046
PD047
PD048
PD049
PD050
PD051
PD052
PD053
PD054
PD055
PD056
PD057
PD058
PD059
PD060
PD061
PD062
PD063
PD064
PD065
PD066
PD067 through 69 : RESERVED
PD070 0
PD071 20
PD072 400
PD073 120
PD074
PD075
PD076
PD077
PD078
PD079 = RESERVED (0.01);
PD118
PD119
PD120
PD121
PD122
PD123
PD124
PD125
PD126
PD127 through 129 = RESERVED
PD141 220
PD142 8.5
PD143 2
PD144 3000
PD145
PD146
PD147
PD148 and 149 : RESERVED
PD150
PD151
PD152
PD153
PD154
PD155
PD156
PD157
PD158
PD159
PD160
PD161
PD162
PD166 through 169 : RESERVED
PD170
PD171
PD172
PD173
PD174
PD175
PD176
PD177
PD178
PD179
PD180
PD181
PD182
PD183
PD184 through 250: RESERVED
</pre>
Thanks in advance.
Last edit: 13 Nov 2023 18:45 by gardenweazel. Reason: Formatting bad
13 Nov 2023 22:32 #285319 by tommylight
Replied by tommylight on topic 7i76E connection to Huanyang HY02D223B
When do you get the OC error? When powering the VFD or when starting it from LinuxCNC?
One thing to check on the VFD, spin up time, set it to 5 seconds.
The following user(s) said Thank You: gardenweazel
  • gardenweazel
  • Elite Member
  • Elite Member
13 Nov 2023 22:47 #285320 by gardenweazel
Replied by gardenweazel on topic 7i76E connection to Huanyang HY02D223B
Hey there,
I get that over current error in LinuxCNC. And only when I click the start button.
Also, did you mean acceleration time? If so, I thought that I had them generously set:
PD014 12
PD015 15
PD016 12
PD017 15
PD018 12
PD019 15
PD020 12
PD021 15
Thanks for your feedback!
13 Nov 2023 23:26 #285323 by tommylight
That is always a wiring error, but what exactly is miss wired needs a bit of figuring out.
Upload the hal and ini file so we can see what is being activated, might help narrow it down.
  • gardenweazel
  • Elite Member
  • Elite Member
13 Nov 2023 23:52 - 13 Nov 2023 23:53 #285324 by gardenweazel
All is good now. I changed pd003 and pd004 to 400 and it took off.
Man this is awesome, so silent and no screaming loud chatter of my old MPCNC machine.
For anyone else 'listening' I also changed pd014 and pd015 to 8 seconds and will likely change some of the remaining pd016 - pd021 setting at some point. Hence, my settings below can be used to set up your Huanyang HY02D223B setup. Simply change what I have indicated in the first line of this reply.
Last edit: 13 Nov 2023 23:53 by gardenweazel. Reason: fixed typos
Time to create page: 0.316 seconds
