black screen after installation of new debian12 Linuxcnc image
15 Nov 2023 07:12 #285466 by geostein8888
Hello,
i downloaded the new debain 12 2.91 image and installed it. Everything went fine no Errors. But after the reboot i got the start menu then some linux output and everything ended up in a black screen. I can connect via ssh to the machine and work here, but i have no display on it self.
I have a standard msi mini atx socket 1155 board with intel graphics and an i5 prozessor, Before i had the debian 10 linuxcnc image running fine on the same hardware
Georg
15 Nov 2023 12:38 #285496 by tommylight
Boot the pc, hold down the shift key, when GRUB menu appears press E, add "nomodeset" after "quiet splash", press F10
15 Nov 2023 13:11 #285504 by geostein8888
there is no "quiet splash" in the script
15 Nov 2023 13:32 #285510 by geostein8888
i found out now the following - why is there a Xeon graphics driver installed, i have a standard Intel H61 Éxpress chipset
lspci -k | grep -EA3 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller (rev 09)
Subsystem: Gigabyte Technology Co., Ltd Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
Kernel driver in use: i915
Kernel modules: i915
Time to create page: 0.071 seconds
