Problem tooloffset
- choqui2010
- Topic Author
2 years 11 months ago #286493
by choqui2010
Problem tooloffset was created by choqui2010
Hello guys, I am having problems with tool compensation on a small 5-axis machine, I am using 5axiskins, for example in the tool table I put 100mm and I give it T1M6G43 in the W axis it shows me -100, I put Z- 100 and I give it Z0 followed by W0, this is where the pivot point should be at the tip of the tool but it doesn't, it doesn't change anything. What am I failing? I did not modify anything in HAL or INI. I thank you in advance for the help
- Thank you received: 2177
2 years 11 months ago #286522
Replied by Aciera on topic Problem tooloffset
Seems like you are posting again about the same problem we are already dealing with here:
forum.linuxcnc.org/10-advanced-configura...fset?start=10#286490
Please do not double post.
Time to create page: 0.120 seconds
