Float Switch has disabled jogging
- JACOBH
28 Nov 2023 22:44 #286735
by JACOBH
Float Switch has disabled jogging was created by JACOBH
I know this was addressed in January but my situation is a bit different. The disable Jog setting option is disabled so i can't click to override. The AUTO HOMING works but when we goto manaully move the plasma with either keyboard keys or on screen arrows we get "FLOAT SWITCH HAS DISABLED JOGGING". Do you have tricks to help us resolve this issue? Should we replace the float switch? Thank you
- phillc54
- Thank you received: 2100
28 Nov 2023 23:33 #286737
by phillc54
Replied by phillc54 on topic Float Switch has disabled jogging
You need to ensure that the float switch is not active. Is it on all the time?
- JACOBH
29 Nov 2023 14:40 #286788
by JACOBH
Replied by JACOBH on topic Float Switch has disabled jogging
How do i know when the float switch is on?
- phillc54
30 Nov 2023 00:33 #286824
by phillc54
If you are using PlasmaC or QtPlasmaC then there are indicators on the GUI, the indicator should only be lit when the float switch is activated.
Another option would be to use halshow to monitor the HAL pin directly.
- JACOBH
30 Nov 2023 02:04 #286828
by JACOBH
yes we have QtPlasmaC - i will go check that out and report back - really appreciate your assistance
- JACOBH
01 Dec 2023 16:40 #286974
by JACOBH
We found that the FLOAT light was indicating on and found a short in the float switch... it is now fixed - Thank you for you quick response and much needed assistance - have a great day !
The following user(s) said Thank You: phillc54, tommylight
Time to create page: 0.401 seconds
