linuxcnc terminated with an error
30 Nov 2023 11:33 #286863 by bobwolf
linuxcnc terminated with an error was created by bobwolf
hi i'm Roberto a new/old user of linuxcnc
excuse my bad basic english
i've resume my old cncmill and i try to use again
in the old hard/soft configuration i use linuxcnc 2.7 with weezy and few year ago work well
now i've upgrade to linuxcnc 2.8 from 2.7 keeping the old operative system
the new linuxcnc 2.9 system installation don't work on my old pc
sometime... more then sometimes... the program stop and exit with an errorlinuxcnc do error in idle and in run mode
can someone help me???
in attachments the report files
thanks
Roberto from Italy
File Name: linuxcnc.d...ugNj.txt
File Size:0 KB
File Name: linuxcnc.p...zQPS.txt
File Size:1 KB
File Name: linuxcnc.report.txt
File Size:11 KB
File Name: linuxcnc_info.txt
File Size:4 KB
  • Moderator
  • Moderator
30 Nov 2023 15:22 #286879 by tommylight
Replied by tommylight on topic linuxcnc terminated with an error
From a quick glance looks like memory issues.
Will take a closer look later if possible.
01 Dec 2023 10:01 #286953 by bobwolf
Replied by bobwolf on topic linuxcnc terminated with an error
thanks
i've check the bios
the pc has 480MB of memory... but i've istalled 1GB, two ram of 512 MB...
maybe the motherboard don't work correctly...
i'll try to fix it or i'll buy a new pc
did you see other problems inthe report files???
grazie
Roberto
  • Moderator
  • Moderator
01 Dec 2023 14:31 #286968 by tommylight
Test with only one RAM stick, see what works.
Replace the RAM when you can, 1GB is not enough, 4GB are OK, 8GB are nice to have.
03 Dec 2023 20:14 #287138 by bobwolf
hello
the ram is ok... maybe the motherboard is broken :-(
was a pc 15/20 year old ;-)
i'll try to find another pc.... with better performance i hope
thanks for all
ciao
Roberto
08 Dec 2023 16:26 #287545 by bobwolf
I changed the PC to a more modern one and tried to install the linuxcnc 2.9.1 image... but at that point new problems arose:
forum.linuxcnc.org/39-pncconf/50902-no-7...nuxcnc-2-9-1-pncconf
I also tried to understand why the 7i43 is no longer in the 2.9.1 installation image
forum.linuxcnc.org/38-general-linuxcnc-q...out-of-linucnc-2-9-1
You know something about this???
  • Moderator
  • Moderator
08 Dec 2023 16:33 #287548 by tommylight
@BobWolf,
You have not replied to PCW answers in one of those topics yet, so why are you repeating the same thing over multiple topics? This makes a mess for anyone trying to help as we can not follow what has already been answered.
08 Dec 2023 17:00 #287555 by bobwolf
OK! I got it
but I also told him in the first answers I gave him that I removed linuxcnc 2.9 to put linuxcnc 2.8, formatting the entire system
the machine works well even with previous versions...
but he never answered me about the reason for removing native support for 7i43 in version 2.9.1 of linuxcnc
and that's why I opened a post in the general linux question section
for me that topic can easily be closed... it went beyond the meaning of the title of the post and I practically solved it (Italian style)
If you want to help me solve my question in the post I made in general questions, I thank you in advance
otherwise friends like before ;-)
ciao
Roberto
  • Moderator
  • Moderator
08 Dec 2023 17:15 #287558 by tommylight
Scuzzi Roberto, but i have no idea if it ever was there or not as i have never used a 7i43, but i did use a lot of other Mesa boards, a lot! :)
08 Dec 2023 17:31 #287562 by bobwolf
sorry if I waste your time:
What type of mesa boards do you use or have you used?
if they are the type with serial communication (ethernet type for example) can you insert the firmware that is convenient for your machine into the internal eeprom??? a few years ago after burning a 7i43 I bought a 7i90 and I went crazy inserting the firmware I needed... after which I bought a much simpler 7i43 again
now that I have restarted the old self-built CNC milling machine I don't really want to go crazy configuring it... I use it as a hobby and if it has to become a job...
Time to create page: 0.278 seconds
