Parallel pin setup
04 Nov 2010 19:50 #5085
by bchager
Parallel pin setup was created by bchager
I have a Toshiba TB6560AHQ cont brd. The pin definitions are nothing like the defs in the stepconf Wizard. can any one help with this? Is there a work around for this or another parallel port setup? I am new at this and would apreciate all the help i can get regards BCH
04 Nov 2010 20:53 #5086
by BigJohnT
Replied by BigJohnT on topic Re:Parallel pin setup
Kinda hard to guess without your pin definitions or a link to them...
04 Nov 2010 22:36 #5091
Replied by andypugh on topic Re:Parallel pin setup
bchager wrote:
Every pin in the stepconf wizard is configurable to be anything you want it to be, just by selecting from the drop-down boxes. That's rather the point of it.
I am puzzled as to what you mean?
06 Nov 2010 18:21 #5117
by bchager
Replied by bchager on topic Re:Parallel pin setup
I finaly figured out the answer to my first problembut now I have another one. after getting all three steppers working I tried to use the program to cut the EMC sign out and all it will use is the Y axis. in the stepcfg wisard all three will run in test mode, does any one have an answer? thanks in advance BCH
06 Nov 2010 22:33 #5121
by Rick G
Replied by Rick G on topic Re:Parallel pin setup
You probably need to post more information, such as how you set everything up or perhaps post your set up files.
Rick G
Rick G
06 Nov 2010 23:07 #5123
by BigJohnT
Does your X and Z axis have an enable that needs connecting?
Can you jog X and Z in Axis?
Time to create page: 0.301 seconds
