Debian bookworm can't install git
- 0jw
02 Dec 2023 11:09 - 02 Dec 2023 11:12 #287013
by 0jw
Debian bookworm can't install git was created by 0jw
Hello, I'm hoping someone can help me. I can't install git on Debian 12 bookworm. I've been installing offline and then updating. I've tried editing the source list in Nano and synaptic, tried a fresh image, changing from Rufus to Unetbootin. nothing seems o work. any help is greatly appreciated!
sudo apt-get install git
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package git is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'git' has no installation candidate
Last edit: 02 Dec 2023 11:12 by 0jw.
- Thank you received: 4138
02 Dec 2023 11:41 #287014
Replied by rodw on topic Debian bookworm can't install git
I'm pretty sure if you install without an internet connection, the apt sources will not be set up correctly if you connect to the internet later. That means it is unable to get packages.
share the output of this command
cat /etc/apt/sources.listPlease Log in or Create an account to join the conversation.
- Thank you received: 7461
02 Dec 2023 13:45 #287023
Did you do a
sudo apt update
before trying to install?
Replied by tommylight on topic Debian bookworm can't install git
I always install with NO internet connection, it always works.I'm pretty sure if you install without an internet connection, the apt sources will not be set up correctly if you connect to the internet later.
Did you do a
sudo apt update
- 0jw
02 Dec 2023 14:12 #287025
by 0jw
Replied by 0jw on topic Debian bookworm can't install git
Yeah that's makes sense, but I'm not sure how to edit it.
# deb cdrom:[Debian GNU/Linux 12 _Bookworm_ - Official Snapshot amd64 LIVE/INSTALL Binary 20231016-21:54]/ bookworm contrib main non-free non-free-firmware
- 0jw
02 Dec 2023 14:28 #287026
by 0jw
Yes, I used sudo apt get with the same results. the package manager repository is using some .io domains. nit sure if that matters
This is what I see in the package manager repository. but it doesn't match the sources.list. even after editing the sources.list I still the errors and some new ones.
deb packagecloud.io/rodw-au/rodw-au/debian/ bookworm main
deb-src packagecloud.io/rodw-au/rodw-au/debian/ bookworm main
deb www.linuxcnc.org/ bookworm 2.9-uspace
deb repository.qtpyvcp.com/apt/ develop main
deb cdrom:[Debian GNU/Linux 12 _Bookworm_ - Official Snapshot amd64 LIVE/INSTALL Binary 20231016-21:54]/ bookworm non-free-firmware non-free main contrib
02 Dec 2023 18:07 #287036
Sudo apt update
- 0jw
02 Dec 2023 18:26 #287041
by 0jw
I definitely tried Sudo apt update. Maybe a better option is to install buster and upgrade it to bookworm instead. Could this be a root issue?
02 Dec 2023 18:59 - 02 Dec 2023 19:03 #287044
edit your file as follows
replace the contents with:
then type
Our installer follows best practice and adds all of the third party repositories (including linuxcnc) in other folders under the /etc/apt/ folder.
sources.list only contains the debian defaults which are set dynamically by the installer.[
Despite what Tommy thinks, you do need to have internet connection when running the installer. Otherwise, apt is set up to only get programs from your CD which you probably don't have. This is your issue.Yeah that's makes sense, but I'm not sure how to edit it.
sudo geany /etc/apt/sources.listreplace the contents with:
deb https://deb.debian.org/debian/ bookworm main contrib non-free non-free-firmware
deb https://security.debian.org/ bookworm-security non-free contrib main non-free-firmware
deb https://deb.debian.org/debian/ bookworm-updates non-free contrib main non-free-firmwarethen type
sudo apt updateOur installer follows best practice and adds all of the third party repositories (including linuxcnc) in other folders under the /etc/apt/ folder.
Last edit: 02 Dec 2023 19:03 by rodw.
Time to create page: 0.108 seconds
