Odd failure
06 Dec 2023 18:20 - 06 Dec 2023 18:21 #287370 by sajurcaju
Odd failure was created by sajurcaju
I have a home built cnc router, running Linux Mint 20 and LinuxCNC 2.8.4 with Axis. G540 driver, XYZ plus A is slaved to X (there are two steppers on the X axis). I'm using DeskProto for CAM. This router has worked fine for several years.
I ran variations of some test gcode that puts holes at the corners of a 4" square. This worked fine the first two variations.
When I ran the third variation, it started with the hole in the upper left (no problem). When it moved toward the upper right, at about 1" it stopped completely. My g540 fault light was lit.
I cleared the fault by turning the power to the g540 off and then on. Resetting zero to the same location as before, and using the jog button to move the same way caused no problem. Moving the same way by manually executing gcode via MDI (same feed rate) caused no problem.
Going back to a previous variation (that worked before), I had the same problem. In this variation, the gcode started cutting upper left, then cut lower left, then moves toward lower right and at about 1"  stopped completely.
It looks like something broke (gcode that worked before no longer works, so it's not the gcode). I have not been able to detect the problem with either manual jog or manual gcode execution.
How do I troubleshoot this?
Thanks,
Steve
Last edit: 06 Dec 2023 18:21 by sajurcaju. Reason: added that this is a working router, not new
06 Dec 2023 19:09 #287373 by PCW
Replied by PCW on topic Odd failure
My first guess would be a broken wire...
06 Dec 2023 19:12 #287374 by sajurcaju
Replied by sajurcaju on topic Odd failure
This is a possibility, but odd. The problem only occurs during program execution. It's not broken in manual movements.
06 Dec 2023 19:17 #287375 by PCW
Might be power supply related (either drooping or insufficient output capacitance
to absorb BEMF when decelerating resulting in an overvoltage)
or maybe one of the G540 individual drives is failing
  • Moderator
  • Moderator
06 Dec 2023 20:47 #287388 by tommylight
Replied by tommylight on topic Odd failure
Check the DB9 motor connectors first for bad connection.
Do they also have resistors for setting the motor current? If not, add them, se manual.
13 Dec 2023 15:16 #288048 by sajurcaju
Wires were a good thought, I did find one sharp bend I did not like.
In the end, my problem was self induced. I tightened some places that I thought might help backlash--instead, I put too much friction in. The fault occurred during a rapid move as a result. It wasn't obvious to me since at the beginning it only occurred under program control; this changed to intermittent later.
Time to create page: 0.325 seconds
