Help with esp32?
- OneMyr
07 Dec 2023 17:08 - 07 Dec 2023 19:22 #287462
by OneMyr
Help with esp32? was created by OneMyr
Hello there
I was looking for a way to run Linux cnc with a esp32 working as a step generator like i saw in a fórum with jzolee work. But when i finished installing and doing The halcompile, when i tried to run The Program, this is What i got
drive.google.com/file/d/1Lx-7ENpbt4-lK1O...sy/view?usp=drivesdk
This erro shows before The Program status, and
drive.google.com/file/d/1L_EdgUyE28wN9fU...AD/view?usp=drivesdk
The Axis was in a strange position and i Just can't press The Estop Button.
I really don't know How to fix this, maybe i am kinda dumb, but cant anyone give a little help.
Thanks, and Sorry for taking yout time
Last edit: 07 Dec 2023 19:22 by OneMyr.
- Thank you received: 4648
09 Dec 2023 18:24 #287702
Replied by andypugh on topic Help with esp32?
This looks like an unusually self-explanatory error message. I commend the programmer
Maybe this will help you decipher what it is trying to tell you?
linuxcnc.org/docs/html/config/ini-config...sub:ini:sec:rs274ngc
The following user(s) said Thank You: OneMyr
- OneMyr
11 Dec 2023 17:52 - 11 Dec 2023 17:56 #287872
by OneMyr
Replied by OneMyr on topic Help with esp32?
Thanks, after a few tries The error disappeared, and yeah just like i said, i feel a little dumb because it was simple haha. but i still cannot turn The machine on, The e stop Button looks like If its pressed, Just like in The video bellow
drive.google.com/file/d/1PgCSohU4uwKuCqE...O7/view?usp=drivesdk
Id put a example gcode and tried to run, but without any sucess
Last edit: 11 Dec 2023 17:56 by OneMyr.
11 Dec 2023 23:16 #287890
This looks like a HAL configuration problem. Something is triggering the E-stop. Can you attach the HAL and INI files from your config?
- OneMyr
12 Dec 2023 11:09 #287932
by OneMyr
of course i can. i will let both below, i am a little lost here, cuz i dont really know how to handle the hal file. also thanks again!
12 Dec 2023 11:31 #287933
I think that the problem is somewhere in these lines:
Normally there is a very short loop:
Yours is set up to additionally depend on the "udp.ready" pin going true.
You can check if it does with the "halmeter" tool, available from the "machine" menu in the axis gui, other places in other guis, or with the command "halcmd loadusr halmeter" at the command line. You can load as many as you need to watch multiple pins. Or use "halshow" to "watch" multiple pins.
However, I also noticed:
Which is unusual. In fact I just tried loading an extra thread after loading emcmot and it caused a segfault.
As your udp-thread is the same speed as your servo thread, try removing the udp-thread. (remove or comment-out the loadrt thread.... line) and add the udp component to the servo thread:
loadrt and2 names=no-estop
addf no-estop servo-thread
net no-estop-a iocontrol.0.user-enable-out no-estop.in0
net no-estop-b udp.ready no-estop.in1
net no-estop-out no-estop.out iocontrol.0.emc-enable-inNormally there is a very short loop:
net e-stop-loop iocontrol.0.user-enable-out iocontrol.0.emc-enable-inYours is set up to additionally depend on the "udp.ready" pin going true.
loadrt threads name1=udp-thread period1=[EMCMOT]UDP_PERIOD fp1=1
addf udp udp-threadWhich is unusual. In fact I just tried loading an extra thread after loading emcmot and it caused a segfault.
addf udp servo-thread
- OneMyr
12 Dec 2023 12:18 #287938
by OneMyr
okay... ill try my best, later i return the results back to you. and again, thanks.
- OneMyr
12 Dec 2023 19:07 #287964
by OneMyr
After a lot of tries, i coudnt make it work. instead id got a lot of errors, the last one was this report. i also got a lot of different errors before, but the was just for testing.Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.4-1-gb7824717b
Machine configuration directory is '/home/cnc/linuxcnc/configs/UDP2'
Machine configuration file is 'UDP2.ini'
INIFILE=/home/cnc/linuxcnc/configs/UDP2/UDP2.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./UDP2.hal
twopass: Error in file ./UDP2.hal:
invalid command name "0setp"
Command not found using ::auto_path=
/usr/lib/tcltk/linuxcnc /usr/share/tcltk/tcl8.6 /usr/share/tcltk /usr/lib /usr/local/lib/tcltk /usr/local/share/tcltk /usr/lib/tcltk/x86_64-linux-gnu /usr/lib/tcltk /usr/lib/tcltk/tcl8.6
Debug file information:
1328
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtime
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
1328
12 Dec 2023 23:37 #287987
Looks like a typo. "0setp" should probably be "setp"
- OneMyr
13 Dec 2023 13:46 #288033
by OneMyr
Okay thanks again, it wasnt just this, but after a few tries i managed to turn the machine on, but when i try to move one of the axis, the program shows an error like in the image
yeah i know the error is in portuguese, but it says "axis movement calculation error"
and it repeat for every axis
Time to create page: 0.133 seconds
