Help with esp32?
13 Dec 2023 14:47 #288045 by andypugh
Replied by andypugh on topic Help with esp32?
It sounds like the position feedback pins are not connected.
First, does the ESP32 component send and position feedback?
15 Dec 2023 12:28 #288213 by OneMyr
Replied by OneMyr on topic Help with esp32?
hello again, actually, after seeing the halmeter it not only dont send the feedback but also the "udp ready" only appears as false, maybe its the esp?
the code is basically the same of jzolee, but also the program is running cause i can ping the esp and when i use nmap on udp port, the 5000 port are open
15 Dec 2023 15:47 #288224 by andypugh
I suspect that the "udp" component isn't actually running.
But I have no idea what the udp component is, or where you found it. (You haven't said)
15 Dec 2023 16:24 - 15 Dec 2023 16:27 #288232 by OneMyr
oh, i literally forgot to show the udp fiiles.
github.com/jzolee/HAL2UDP i picked up directly from jzolee git, and did a few changes, like removing the pwm functions, only because i dont really need then(i guess).
i was also looking at this other forum pages forum.linuxcnc.org/18-computer/42414-lin...-using-esp32?start=0
Last edit: 15 Dec 2023 16:27 by OneMyr.
26 Dec 2023 20:43 #289111 by andypugh
Is the IP address correct?
github.com/jzolee/HAL2UDP/blob/main/Linu...0driver/udp.comp#L92
If you open a terminal and type
halcmd show funct
How long is the "udp" function taking to execute? If it is zero, then it isn't running.
Time to create page: 0.131 seconds
