Stepper only going in one direction
2 years 10 months ago #288385 by robertjenkins
Hi
My Denford Microrouter has been working fine until this morning. When homing the X axis, the cutter went off in the wrong direction until it reached the far end (away from the homing switch) and is stuck there. When I try to jog it in stepconf it won't move (the motor just grinds against the end)
I'd like to narrow down the source of the problem - the software configuration hasn't changed but maybe there's an issue with the parallel port or the cable. Or it could be on the controller board or the stepper itself. I feel that the Hal meter should be able to help me here, but I'm not sure what to do. I've checked that the homing switch is working OK but need help to go further
Thank you
2 years 10 months ago #288386 by robertjenkins
I did an obvious thing which was to temporarily switch round the X and Y pins in stepconf. The problem was still there. Must be a hardware problem on the router, I think
2 years 10 months ago #288389 by bkt
if you add to your gui (if axis) a "debug panel" using these for example ... linuxcnc.org/docs/html/gui/pyvcp.html#_leds ... you can easely debug these hardware problem if exist or not ....
2 years 10 months ago - 2 years 10 months ago #288394 by Mecanix
Stepper drives/motors are notorious for going in only one dir when poorly grounded or not grounded at all. Possible cause; joint corrosion, loose crimping, etc etc. 1. Rule out ground with a DMM, ensure you have <0.5ohm.
Last edit: 2 years 10 months ago by Mecanix.
2 years 10 months ago #288395 by robertjenkins
Thanks. Do you mean the metal body of the motor needs to be grounded? Or one of the pins?
2 years 10 months ago #288397 by tommylight
First re-tighten the connectors on the drives and BOB.
What drives?
Time to create page: 0.333 seconds
