linuxcncrsh error: can't connect to LinuxCNC
- Daddio
- Thank you received: 5
21 Dec 2023 00:43 #288721
by Daddio
linuxcncrsh error: can't connect to LinuxCNC was created by Daddio
Hello all,
I am unable to launch linuxcncrsh. Each time I try to launch linuxcncrsh from terminal, I get this error:
emc/usr_intf/emcrsh.cc 2969: can't connect to LinuxCNC
I am running Debian 12 with the Xfce desktop environment, but was also getting the same error on Debian 10.
I've been working off of this linuxcnc.org/docs/html/man/man1/linuxcncrsh.1.html wiki page. Meaning I've tried starting linuxcncrsh from HAL and from terminal with no luck and just the same error.
What am I missing? Why can't linuxcncrsh connect?
Cheers,
Cheers,
- Thank you received: 426
21 Dec 2023 04:46 #288728
Replied by Cant do this anymore bye all on topic linuxcncrsh error: can't connect to LinuxCNC
Hard to tell without your ini & hal files and the commands you are using. Could be something as simple as a syntax error.
- Daddio
02 Jan 2024 06:08 #289530
by Daddio
Replied by Daddio on topic linuxcncrsh error: can't connect to LinuxCNC
This turned out to be a network problem where my wifi would be killed when linuxcnc started. I had to install wpasupplicant and create wpa_supplicant.conf file. Not sure why it wasn't there, but did the trick.
Time to create page: 0.078 seconds
