- Thank you received: 3
Using additional axis letters will only let you run different tool paths by running them sequentially (ie you would have to wait for one to finish until you could start the other). If that is all you need then it may do what you want but that is not multi-channel use.I copied this from a previous question that seems similar....does the partial answer i pasted below seem appropriate for my desired use?...
