Backing up your work
- RyanB
30 Dec 2023 22:45 #289393
by RyanB
Backing up your work was created by RyanB
I've installed Linux CNC, got things up and running, installed some other linux programs to make life a little easier, but I am completely aware that a mistake would take me back to square 1.
Since I am fairly new to linux in general, I'd like to save the entire system on a second drive, having 3-5 saves back, so if I do screw something up I can just go back to when I did have it working. How would I go about this?
- Online
- Thank you received: 4138
30 Dec 2023 23:01 #289394
Replied by rodw on topic Backing up your work
You just need to save the contents of the linuxcnc folder under your home directory.
If you do have a failure, reinstall linuxcnc from the ISO downloads and reinstate your linuxcnc folder.
I just save a snapshot to google drive from time to time
- Serg452
- Thank you received: 5
01 Jan 2024 20:01 #289505
by Serg452
clonezilla.org/downloads.php
Replied by Serg452 on topic Backing up your work
linuxcnc folder will not save linux settings, it is better to make a copy of the diskSince I am fairly new to linux in general, I'd like to save the entire system on a second drive, having 3-5 saves back, so if I do screw something up I can just go back to when I did have it working. How would I go about this?
Time to create page: 0.198 seconds
