Beginner with LinuxCNC and Roland EGX-300, looking for a few pointers
02 Jan 2024 02:29 #289523 by sky_1
Hello,
I'm a newcomer to LinuxCNC. I have (thanks to help from the forum) managed to build LinuxCNC (for Run In Place) on an RT-enabled kernel, and have run the tests, and they pass. That's where I'm at so far.
I've started looking at the extensive documentation at LinuxCNCKnowledgeBase, and it's immense. But I'm technically minded, and will read up anything, I was just hoping for some quick pointers into the areas I should focus on.
Anyone have a few pointers where I should start, given my use-case (which is to use an EGX-300, for engraving from a vector file (I don't mind what format for now).
I have a serial port and parallel port (USB-to-RS232 and USB-to-Centronics) since I didn't know which one would be supported by Linux and LinuxCNC. The ports are reported as:
Bus 001 Device 008: ID 067b:23a3 Prolific Technology, Inc. ATEN Serial Bridge
Bus 001 Device 007: ID 067b:2305 Prolific Technology, Inc. PL2305 Parallel Port
Thanks for any help.
02 Jan 2024 04:15 #289529 by tommylight
Do you plan on developing stuff for LinuxCNC?
Does the machine need something that is already not included with LinuxCNC?
If both are "No", do not use "run in place", use the ISO or Debian 12.4 or LMDE6, very easy to install and run.
Or, maybe i should ask, where did you get the idea to do a "run in place" install?
Serial and USB to parallel do not work with LinuxCNC, normal built in or PCI/PCI-E parallel port cards do work.
Open the machine, take some pictures of the boards and connectors inside, post those here so we can have a look, etc.
03 Jan 2024 21:02 #289696 by sky_1
Thanks for the reply! I'm using 'run in place' because I needed a Linux kernel with some extra (unrelated) patches.
Does LinuxCNC not work at all with USB to Serial or USB to parallel converters, or does it work but poorly?
I assumed that since the EGX-300 uses a high-level language (HPGL-like), and doesn't require direct pulses to stepper motors, that perhaps a lower performance solution like USB-to-Serial or USB-to-Parallel might be adequate. But if LinuxCNC does not function with then at all, then I'll have to re-think things.
I could control the EGX-300 without LinuxCNC, but I had hoped to use it as a learning opportunity, i.e. I'd rather get it running with LinuxCNC than without.
03 Jan 2024 21:53 #289701 by tommylight
No, does not work at all, LinuxCNC must have direct access to hardware to use it, those are software/hardware interfaces.
Get an add on PCI card with NetMOS or MOSChip IC, those usually work out of the box, no drivers needed.
Still, you will have to decide if you want to keep the existing controller (if there is one, you did not provide pictures of the innards) with whatever it came, or get rid of the controller and use LinuxCNC.
I would do the latter in a heartbeat! :)
The following user(s) said Thank You: sky_1
04 Jan 2024 00:24 #289708 by sky_1
Thanks for the advice! I see; in that case, I'll take a two-track approach. I'll work with either C/C++ or Python to program the machine in the HPGL-like format that it uses, whilst also obtaining a PC with PCIe card slot, so I can have a small testbed for learning LinuxCNC, and switch to that once I'm familiar with it.
After some googling, I can see that a "Lenovo P320 Tiny" (I want an ideally small form-factor machine) has a PCIe slot, and it's cheap on ebay, so I'll probably pick that up (unless there are better recommendations for a small, low-cost PC), plus PCIe cards for serial and parallel so I can try them both out.
I'm curious too what's inside the EXG-300, but it's not at the location where I an currently, so I can't take a screwdriver to it just yet : ) But ideally I'd just like to use it as a black box and apply the HPGL-like commands (known as CAMM-GL in Roland speak) via LinuxCNC, and learn about suitable stepper/spindle driver boards over time.
  • adriancph
  • adriancph's Avatar
  • Visitor
  • Visitor
27 May 2024 20:12 #301612 by adriancph
Hi!
I am working on two projects a Roland camm 1 and a LKPF protomat 60C which speaks HPGL. I am wonding if you ended up using Linuxcnc and how this works for you?
Best regards,
Adrian
05 Jun 2024 07:37 - 05 Jun 2024 16:07 #302368 by snowgoer540
<removed spam from thread>
Last edit: 05 Jun 2024 16:07 by snowgoer540.
Time to create page: 0.341 seconds
