Deactivating or disabling a specific axis using HAL
- Bl484
- Topic Author
2 years 9 months ago - 2 years 9 months ago #289821
by Bl484
Deactivating or disabling a specific axis using HAL was created by Bl484
Hello,I would like to inquire about the possibility of deactivating or disabling a specific axis using HAL commands. Specifically, I am attempting to prevent the stepping signal to the X-axis. I have attempted the following command without success.
unlinkp hm2_7i96s.0.stepgen.00.velocity-cmd
How can I deactivate an axis using Hal command?
Last edit: 2 years 9 months ago by Bl484.
- Thank you received: 5334
2 years 9 months ago - 2 years 9 months ago #289823
Replied by PCW on topic Deactivating or disabling a specific axis using HAL
Yes, that would cause a following error...
A cheap trick that will stop motion but not cause an error
would be to set the step time very short:
hm2_7i96s.0.stepgen.00.steplen 10
Last edit: 2 years 9 months ago by PCW.
The following user(s) said Thank You: Bl484
- Bl484
- Topic Author
2 years 9 months ago #289828
by Bl484
Replied by Bl484 on topic Deactivating or disabling a specific axis using HAL
Thank you very much
Time to create page: 0.106 seconds
