When I run linucnc, why it always tells me "Xenomai:/dev/rtheap is missing"
05 Jan 2024 10:13 #289844 by RushA
    I built a RT system using Ubuntu 20.04+Linux 4.19.279+xenomai3.1. I successfully compiled linuxcnc 2.10.0. When I run the linuxcnc, it always shows me an error message "Xenomai:/dev/rtheap is missing". I also run other linuxcnc versions like 2.8. I got the same error message. Please tell me how to solve this problem!
  • Moderator
  • Moderator
05 Jan 2024 23:30 #289911 by tommylight
Is there any particular reason for using such old Linux/Kernel?
Use the official ISO from the downloads page, if there is not need for anything special.
06 Jan 2024 05:20 #289927 by RushA
I don't agree with you. The reason why I use 4.19 kernel, Xenomai ipipe only supports up to 5.4 version.Have you ever seen this topic:https://forum.linuxcnc.org/9-installing-linuxcnc/43981-how-build-linuxcnc-with-xenomai3
You can go to see the last reply. fsabbatini only uses 4.14 kernel, and linuxcnc runs properly.
  • Platinum Member
  • Platinum Member
06 Jan 2024 06:03 #289928 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic When I run linucnc, why it always tells me "Xenomai:/dev/rtheap is missing"
I don't think this is a issue related directly to Linuxcnc, it is more than likely an issue with the kernel config or the installation of the kernel. Maybe post tin the original thread, the OP might be around.
Maybe helpful here
yhbt.net/lore/all/5600F8DE.30705@xenomai.org/
06 Jan 2024 07:04 #289930 by rodw
I wish people would refer to the Downloads page and the docs before trying to implement stuff on old hardware and kernels.
One of the devs put a huge effort into retaining xenomai compatability.
Please start here: linuxcnc.org/downloads/
10 Jan 2024 05:54 #290328 by RushA
Fortunately, I solved this problem."rtheap is missing." is not the main reason. I reinstalled the xenomai using deb packages. The compiling command is "debuild -us -uc". I installed four packages.And then I think the Linuxcnc 2.9 can detect that the environment is xenomai.You'd better refer to this page "www.linuxcnc.org/docs/devel/html/code/building-linuxcnc.html." and continue to finish compilation.
When you encountered "<posix/pthread.h> can't be found.", you should change <posix/pthread.h> to <cobalt/pthread.h> and add additional head files "#include <errno.h> #include <string.h> #include <stdio.h>".
Time to create page: 0.444 seconds
