- LinuxCNC
- General LinuxCNC Questions
- [AXIS 2.9.2] Position in Preview & DRO tabs aren't in sync. Bug?
- Mecanix
- Thank you received: 229
05 Jan 2024 19:43 #289894
by Mecanix
[AXIS 2.9.2] Position in Preview & DRO tabs aren't in sync. Bug? was created by Mecanix
I've just found out my lathe can take a 6mm DOC. It complained and smoked quite a bit, but it did the cut! I'll repair the damage this weekend, turret looks a good 10deg offset and the insert is obviously fried. In a meantime can one of you guys give AXIS (2.9.2) a quick test and see if you are getting the same behaviour?
The DRO tab doesn't sync with the position (that's how I got shafted in setting up the wrong wcs and found out, the hard way). If that's the case for your version of AXIS too, might be something to beware of, perhaps qualify as a bug too.
- cakeslob
- Thank you received: 280
06 Jan 2024 01:06 - 06 Jan 2024 01:25 #289914
by cakeslob
Replied by cakeslob on topic [AXIS 2.9.2] Position in Preview & DRO tabs aren't in sync. Bug?
it doesnt update the DRO tab until you move in the DRO tab. something to do with memory or something, but when the DRO tab is closed it stops updating until you move in the DRO tab.
I think theres an option in bwidget for command when tab is raised that we could use instead to update dro when tab is raised.
something like that, but i dont remember how to make the command work with tcl.
I dont know the implications either
${pane_top}.right itemconfigure numbers -raisecmd "[redraw_dro];"something like that, but i dont remember how to make the command work with tcl.
Last edit: 06 Jan 2024 01:25 by cakeslob.
- Mecanix
06 Jan 2024 10:24 #289945
by Mecanix
Replied by Mecanix on topic [AXIS 2.9.2] Position in Preview & DRO tabs aren't in sync. Bug?
Good hint, thanks. I'll look into this and see if I can get it patched. Seems to be working fine when you load a tool, the offsets updates both preview and DRO tabs correctly. What went wrong is I loaded a tool, focused the Preview tab, MDI my wcs position, went back into DRO and calc/set-up using G10 in the MDI. (Realigned the turret today, needed it badly anyway).
Don't know how to fix AXIS though. Prolly safer to just re enable > View > Show offsets, and ignore this naughty DRO tab altogether.
- Thank you received: 2176
06 Jan 2024 10:29 #289946
Replied by Aciera on topic [AXIS 2.9.2] Position in Preview & DRO tabs aren't in sync. Bug?
That certainly looks like a bug to me, although I cannot reproduce this behavior on my version 2.9.2-14-
- cakeslob
06 Jan 2024 17:27 #289981
by cakeslob
You should be able to, I dont see any commit where it was fixed. Also not the first time this issue has come up.
1. - Open preview, move, do what ever
2. - Open DRO, at this point they are synced
3. Open Preview, move 5mm
4. Open DRO, at this point the DRO should be 5mm behind the Preview
5. Press Top view (or any view ) button from the toolbar, and watch the DRO fix it self
mechanix, if you press one of the view buttons from the toolbar, for you its Y view, while in the DRO tab, it will update the DRO
The following user(s) said Thank You: Mecanix
- Mecanix
06 Jan 2024 19:15 #289986
by Mecanix
That workaround actually work. I'll try to remember for when manual calc and set-up is required. Thanks, Cakeslob
Considering the fact that this issue was raised several time (I didn't know), in other words you're saying this ain't a bug, but a limitation of AXIS and its DRO panel (memory)? Nobody is taking care of AXIS or something? What's the reason behind if you don't mind me asking, lack of tcl experts?
That's too bad, one of the top reason I loveeeee linuxcnc so damn much is because of the magical simplicity of AXIS' gui.
- cakeslob
06 Jan 2024 21:08 - 06 Jan 2024 21:11 #290004
by cakeslob
I dont know why or the actual history, I was under the impression it was something to do with memory, but I dont remember. I just remember seeing a thread about it before I knew how to fix it, and experienced the same issue later.
I think its probably a bug/oversight, and the thing I posted would probably fix it, I just dont know how to do it with the axis.tcl file. We want the dro tab to do the command "redraw_dro", when the tab "numbers" is raised. I just dont know how to link the axis.py command to the axis.tcl file.
The fix is the same as the work around I mentioned. when you press one of the view buttons, it invokes "redraw_dro" . so if our work around works without issue, then it should be fine. I just dont know how to do it, and Im not the kind of guy who likes to make issues, I just prefer to quietly suffer. Since you actually use the DRO, I can do a github issue thing.
You are using the newest version of 2.9? I am using an older one at the moment.
Last edit: 06 Jan 2024 21:11 by cakeslob.
- Mecanix
06 Jan 2024 21:58 - 06 Jan 2024 21:59 #290008
by Mecanix
Too kind. If you don't mind raising this up to the devs, since you got the potential fix for it, at least the how-to pointer, that would be much appreciated from all - myself the first. The DRO tab is quite invaluable for those who manually set-up, would be nice to eventually have it sync'd for all versions. Although I'm on the daily 2.9.2-[devbot] mostly and so I can't say which releases it affects. Prolly most of them.
Last edit: 06 Jan 2024 21:59 by Mecanix.
- phillc54
- Thank you received: 2100
06 Jan 2024 23:56 #290017
by phillc54
Replied by phillc54 on topic [AXIS 2.9.2] Position in Preview & DRO tabs aren't in sync. Bug?
I posted a patch on the
issue
@cakeslob opened so you can try it to make sure it is ok.
Another way to try it is to add the following in a user_command file in the config directory.
Warning: Spoiler!
def redraw_dro():
o.redraw_dro()
TclCommands.redraw_dro = redraw_dro
commands = TclCommands(root_window)
root_window.eval('.pane.top.right itemconfigure numbers -raisecmd redraw_dro')
The following user(s) said Thank You: Aciera, Mecanix
- Mecanix
07 Jan 2024 01:10 - 07 Jan 2024 01:14 #290023
by Mecanix
Last edit: 07 Jan 2024 01:14 by Mecanix.
- LinuxCNC
Time to create page: 0.563 seconds
