TCP - Tool Center Point
- Duatepe
10 Jan 2024 08:42 #290338
by Duatepe
Replied by Duatepe on topic TCP - Tool Center Point
Actually this comes from sim file belongs default example I didnt touch it.
- Thank you received: 2155
10 Jan 2024 08:45 - 10 Jan 2024 08:47 #290339
Replied by Aciera on topic TCP - Tool Center Point
As for the NKCNC5_arge.ini:
If your machine has XYZAC kinematics then you would need to change all the B-axis references to ' C' :
change:
COORDINATES = XYZAB
to
COORDINATES = XYZAC
and change:
[AXIS_B]
to
[AXIS_C]
Then it seems you are missing the kinematic section:[KINS]
For the kinematic and the graphical machine simulation you need these in your hal section:
If you do no want to use the graphical simulation the you need at leas this from the above:
change:
COORDINATES = XYZAB
to
COORDINATES = XYZAC
and change:
[AXIS_B]
to
[AXIS_C]
KINEMATICS = xyzac-trt-kins
JOINTS = 5For the kinematic and the graphical machine simulation you need these in your hal section:
HALCMD = loadusr -W xyzbc-trt-gui
HALCMD = net :table-x joint.0.pos-fb xyzbc-trt-gui.table-x
HALCMD = net :saddle-y joint.1.pos-fb xyzbc-trt-gui.saddle-y
HALCMD = net :spindle-z joint.2.pos-fb xyzbc-trt-gui.spindle-z
HALCMD = net :tilt-b joint.3.pos-fb xyzbc-trt-gui.tilt-b
HALCMD = net :rotate-c joint.4.pos-fb xyzbc-trt-gui.rotate-c
HALCMD = net :tool-offset motion.tooloffset.z
HALCMD = net :tool-offset xyzbc-trt-kins.tool-offset xyzbc-trt-gui.tool-offset
HALCMD = net :x-offset xyzbc-trt-kins.x-offset xyzbc-trt-gui.x-offset
HALCMD = net :z-offset xyzbc-trt-kins.z-offset xyzbc-trt-gui.z-offset
HALCMD = sets :x-offset -20
HALCMD = sets :z-offset -15If you do no want to use the graphical simulation the you need at leas this from the above:
Last edit: 10 Jan 2024 08:47 by Aciera.
- Duatepe
10 Jan 2024 08:48 #290340
by Duatepe
Yes I am trying to manipulate it step by step also I changed the axis but something wrong which I dont know the best one probably to discuss the machine with team mates. Probably it is not good way to handle it in forum. If I can solve it I will share. Now still I am in progress to understand basics
10 Jan 2024 08:55 #290342
You may have missed my last post.
- Duatepe
10 Jan 2024 09:55 #290344
by Duatepe
Now I make some changes on file.
linuxcnc told me about wrong SUBROUTINE_PATH and I changed it by "SUBROUTINE_PATH = ./examples" according to simulation file.
Now I got error when program start to run --> "waiting for s.joints<0>, s.kinematics_type<0> " several times and program shutdown. So I dont know the error to interfere.
Also maybe I should give more details about machine which normally this CNC used NKCNC5_arge.ini
Machine has 3 axises in use, also has 2 axises to perform 5 axis but this motors just stay there in not use which purpose is observing.
I attached the last file.
- Duatepe
10 Jan 2024 10:48 #290346
by Duatepe
I made the command line below and program opened
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=toolchange epilog=change_epilog
REMAP=M10 modalgroup=6 ngc=m10
REMAP=M11 modalgroup=6 ngc=m11
REMAP=M12 modalgroup=6 ngc=m12
REMAP=M13 modalgroup=6 ngc=m13
REMAP=M14 modalgroup=6 ngc=m14
REMAP=M15 modalgroup=6 ngc=m15
REMAP=M16 modalgroup=6 ngc=m16
REMAP=M17 modalgroup=6 ngc=m17
REMAP=M18 modalgroup=6 ngc=m18
- Duatepe
15 Jan 2024 10:51 #290751
by Duatepe
Hi Aciera
I am trying to move the coordinate axises towards the workpiece position. I mean I make move the workpiece in machine border with Touch Off in red-line in application but coordinate axises still stop on 0,0,0 position actually I want them to move with workpiece which I can start the machine, then I am getting error with borders.
- brendagibbs
31 Jul 2026 04:09 #348257
by brendagibbs
Replied by brendagibbs on topic TCP - Tool Center Point
TCP is where the magic (and head-scratching) happens in 5-axis machining. Whether you're using G43.4 style dynamic TCP or delegating coordinate transformations to your CAM post-processor, having LinuxCNC handle real-time spatial transformations keeps feed rates consistent across multi-axis arcs. Super helpful thread for anyone moving beyond standard 3-axis setups!"
- Thank you received: 7444
31 Jul 2026 04:13 #348258
Replied by tommylight on topic TCP - Tool Center Point
I feel a spam coming on...
31 Jul 2026 05:14 #348265
Yes, I'm pretty sure we can delete that one.
Time to create page: 0.188 seconds
