joint 0 on limit switch error
09 Jan 2024 16:17 #290283 by BatUnt
joint 0 on limit switch error was created by BatUnt
hello, I used linux cnc from a mesa 7i96 board, everything worked fine until now joint 0 on limit switch error homing is done fine and when I want to run the program it throws me this problem. thank you
09 Jan 2024 16:51 #290284 by BatUnt
Replied by BatUnt on topic joint 0 on limit switch error
Attachment not found
09 Jan 2024 17:14 #290285 by PCW
Replied by PCW on topic joint 0 on limit switch error
Have you verified that your limit switch is working with halshow?
09 Jan 2024 17:56 #290286 by BatUnt
both work, the wiring is fine, but when I want to start the spindle manually, it throws this error
  • Moderator
  • Moderator
09 Jan 2024 18:02 #290287 by tommylight
Replied by tommylight on topic joint 0 on limit switch error
That is interference caused, does the machine have proper grounding and did you change the power socket?
The following user(s) said Thank You: BatUnt
09 Jan 2024 18:20 #290289 by BatUnt
I moved the machine to another workshop, maybe I have a bad socket, I'll try
09 Jan 2024 19:18 #290295 by BatUnt
thank you, problem solved, the problem was in the power supply
Time to create page: 0.352 seconds
