CHIRON FZ22L LinuxCNC retrofit
2 years 4 months ago - 2 years 4 months ago #303284 by Dominik
9
Last edit: 2 years 4 months ago by Dominik.
2 years 4 months ago #303371 by Dominik
Poštovanje, zanima me da li popravljate strojeve na terenu? Odnosno da li bi Vi mogli pomoći spojiti stroj na LinuxCNC, imate li neki kontakt? LIjep Pozdrav, Dominik
2 years 4 months ago #303662 by Dominik
Hello everyone, I have a problem with pncconf I don't know how to configure all the cards it shows just the 7i92TH but it doesn't recognize the 7i74 and 7i77, I did the (mesaflash device 7i92T write 7i92_7i77_7i74d.bin), I tried also the mesa configuration tool with the package installer (mesact) but I get an error "Dependency is not satisfiable: python3-packaging", does anyone know what should I do or how to fix the problem. Thanks, Dominik
2 years 4 months ago #303663 by PCW
Replied by PCW on topic CHIRON FZ22L LinuxCNC retrofit
I would choose 7I92+ 7I77 in pncconf
configure the 7I77 in pncconf including the encoders
and analog outputs.
Then I would add the additional I/O by editing the hal file
The following user(s) said Thank You: Dominik
2 years 4 months ago #304051 by Dominik
Hello everyone, my setup still doesn't work I don't know why, it is like the 7i92T doesn't communicate with 7i74 + i/o boards and 7i77 I did the mesaflash and everything and the pncconf, buildbot... I don't know if I need the smart serial install? (I couldn't find how to install it) or the pin file? I installed the Mesa CT also, I checked the DB25 connectors they are wired correctly...
(I copied the hal and ini files from "anfanger" he had a similar machine and all the same boards as I use")
When i try to run linuxcnc i get:
and I am stuck here for a few afternoons :/
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
Machine configuration directory is '/home/cnc/linuxcnc/configs/test'
Machine configuration file is 'test.ini'
INIFILE=/home/cnc/linuxcnc/configs/test/test.ini
VERSION=1.1
PARAMETER_FILE=igor.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./hallib/core_igor.hal
INFO CLASSICLADDER-   No ladder GUI requested-Realtime runs till HAL closes.
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:12:80:09
hm2_eth: discovered 7I92T
hm2/hm2_7i92.0: Low Level init 0.15
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0:     IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0:     IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0:     IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0:     IO Pin 003 (P2-15): IOPort
hm2/hm2_7i92.0:     IO Pin 004 (P2-03): IOPort
hm2/hm2_7i92.0:     IO Pin 005 (P2-16): IOPort
hm2/hm2_7i92.0:     IO Pin 006 (P2-04): IOPort
hm2/hm2_7i92.0:     IO Pin 007 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i92.0:     IO Pin 008 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 009 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 010 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 011 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 012 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 013 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 014 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 015 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 016 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 017 (P1-01): IOPort
hm2/hm2_7i92.0:     IO Pin 018 (P1-14): IOPort
hm2/hm2_7i92.0:     IO Pin 019 (P1-02): IOPort
hm2/hm2_7i92.0:     IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0:     IO Pin 021 (P1-03): IOPort
hm2/hm2_7i92.0:     IO Pin 022 (P1-16): IOPort
hm2/hm2_7i92.0:     IO Pin 023 (P1-04): IOPort
hm2/hm2_7i92.0:     IO Pin 024 (P1-17): IOPort
hm2/hm2_7i92.0:     IO Pin 025 (P1-05): IOPort
hm2/hm2_7i92.0:     IO Pin 026 (P1-06): IOPort
hm2/hm2_7i92.0:     IO Pin 027 (P1-07): IOPort
hm2/hm2_7i92.0:     IO Pin 028 (P1-08): IOPort
hm2/hm2_7i92.0:     IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0:     IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0:     IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0:     IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0:     IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
creating ladder-state
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./hallib/core_igor.hal:55: Pin 'hm2_7i92.0.7i71.1.1.output-00' does not exist
4508
Stopping realtime threads
Unloading hal components
2 years 4 months ago - 2 years 4 months ago #304053 by PCW
1. The symptoms (not finding any sserial remotes)  do point to 25 pin cable issues
(checking the encoder inputs on the 7I77 would  verify the connections there)
2. Can you post your hal/ini files
Last edit: 2 years 4 months ago by PCW.
Time to create page: 0.432 seconds
