Raspberry pi 5
2 years 9 months ago - 2 years 9 months ago #290998 by rohit269
Raspberry pi 5 was created by rohit269
  I am install linuxcnc 2.9.2 on raspberry pi5  and  I am  completing all  setting for Linux cnc lathe then I started linuxcnc and I found error and error picture I am also attached please see and guide me how to solve this problem
Last edit: 2 years 9 months ago by rohit269.
2 years 9 months ago #291012 by Cant do this anymore bye all
As per:
linuxcnc.org/docs/html/drivers/hal_pi_gpio.html
7. Known Bugs
At the moment (2023-07-16) this driver only seems to work on Raspbian as the generic Debian image does not set up the correct interfaces in /dev/gpiomem and restricts access to the /sys/mem interface.
2 years 9 months ago #291013 by rohit269
Replied by rohit269 on topic Raspberry pi 5
Thanks for reply sir please tell now what is solution of this problem
2 years 9 months ago #291019 by JT
Replied by JT on topic Raspberry pi 5
Don't use screen shots taken at a bad angle impossible to read. Copy and paste the text only.
JT
2 years 9 months ago - 2 years 9 months ago #291034 by rohit269
 Thanks for reply sir i am attached error please see
2 years 9 months ago #291056 by tommylight
Replied by tommylight on topic Raspberry pi 5
HAL_PI_GPIO: can't open /dev/gpiomem: 2 - No such file or directory If the error is 'permission denied' then try adding the user who runs LinuxCNC to the gpio group: sudo gpasswd -a username gpio HAL_PI_GPIO: can't open /dev/mem: 13 - Permission denied hal_pi_gpio: rtapi_app_main: Operation not permitted (-1)
try
where username should be PI or whatever user name you are using.
Time to create page: 0.124 seconds
