7i92tm fallback corrupted
- 0jw
26 Jan 2024 21:18 #291686
by 0jw
7i92tm fallback corrupted was created by 0jw
Hello, I have a new 7i92tm, I've had it for about 6 hours. I knew something was wrong initially trying to make a connection. I never got it to ping with jumper 6 up or down. But recently when turning it back on it started flashing along with the cheap 5 axis Bob with the red led /DONE LED CR2 on. I pulled 5v from the 5 axis board and moved both jumpers up and still the red led is on.
the user manual isn't very clear about what to do at this point other than mentioning some sort of jtag programmer. I'm really hoping I can get this fixed but I definitely need some guidance.
can anyone help me with a suitable programer to do the job and what needs to be done?
- Thank you received: 5308
26 Jan 2024 22:03 - 26 Jan 2024 22:07 #291688
Replied by PCW on topic 7i92tm fallback corrupted
I would first verify that the 5V power connections to P4 are secure,
the power wires are not too long and the 5V supply is within
specifications. With both IP address jumpers up you should get a flashing
/INIT LED but /DONE should extinguish immediately after power up.
A blinking /DONE LED most likely indicates a power issue.
Last edit: 26 Jan 2024 22:07 by PCW.
The following user(s) said Thank You: 0jw
- 0jw
26 Jan 2024 22:44 #291691
by 0jw
Replied by 0jw on topic 7i92tm fallback corrupted
Wow that was absolutely the problem! Just tested with it plugged directly into the pc and a different ethernet cord and got it to ping. Thank you so much!!!
I was pulling 5V off of a combination power supply and that's definitely what was causing the problem.
Time to create page: 0.595 seconds
