LinuxCNC Mesa 7i96s installation
- garja
- Thank you received: 9
26 Jan 2024 23:35 #291697
by garja
LinuxCNC Mesa 7i96s installation was created by garja
I'm having a heck of a time getting Linuxcnc Debian 2.9.2 installed and working correctly. I've downloaded the iso rod has a link to in his post. I have no problem getting the Linuxcnc installed. It's when I try to run the pncconf wizzard, I can get it completed and open Linuxcnc but then everything is greyed out where I have to option to try and jog the stepper motors I have connected. I am able to connect to my Mesa 7i96s card easy and am able to ping it. Am I missing some steps? Rod has instructions to install QTPYVCP and probe basic:sudo apt install python3-qtpyvc and Installation of Ethercat - sudo apt install ethercat-master libethercat-dev. He points to a readme file located in the home directory, which I am able to locate and follow the instructions to a T but there are always errors.
I'm wondering what I'm missing? Should I be installing the Mesa Configuration tool and using it to set through the configuration? Do I have to have ethercat installed for Linuxcnc to communicate with my 7i96s board?
I've been messing with this for several days and honestly about to pull what little hair I have left, out. If someone could maybe give me the steps in the order I have to complete them, maybe that will help? I really want to learn Linuxcnc and get it humming.
Thanks in advance for your help.
Garlen
Garlen
The following user(s) said Thank You: behai
- Thank you received: 5308
27 Jan 2024 01:37 #291706
Replied by PCW on topic LinuxCNC Mesa 7i96s installation
No, you do not need Ethercat for the 7I96S, it uses normal Ethernet
You can use either pncconf or mesact, both will make working configurations for a 7I96S
- zz912
- Thank you received: 98
28 Jan 2024 19:32 #291818
by zz912
Replied by zz912 on topic LinuxCNC Mesa 7i96s installation
It sounds like GUI problem. Exactly using GUI. What GUI do you use? Gmoccapy? Axis? Other? Can you control 7i96s outputs via halshow?
- garja
28 Jan 2024 20:32 #291827
by garja
Replied by garja on topic LinuxCNC Mesa 7i96s installation
Thanks for your reply ZZ912. I ran the Pnccong and selected Gmoccapy as my GUI. I've never tried controlling the outputs via halshow. I'll have to lookup some information about halshow. I'm absolutely brand new at this so I'm as green as can be.
- zz912
28 Jan 2024 20:47 #291829
by zz912
Look here:
- garja
29 Jan 2024 17:17 #291908
by garja
Thanks for providing the link to the YouTube Video zz912!
Time to create page: 0.093 seconds
