Linuxcncrsh - set mode mdi every time?
- Daddio
- Thank you received: 5
31 Jan 2024 06:16 #292046
by Daddio
Linuxcncrsh - set mode mdi every time? was created by Daddio
Hi all,
I'm connected to my machine via linuxcncrsh. Every time I move I need to first set the mode to MDI by sending SET MODE MDI command which I then follow with a SET MDI G1X1Y1, for example. After the first dozen moves or so this becomes a real pain. Is there a way to persistently set the mode to MDI?
Thanks!
Thanks!
03 Feb 2024 10:24 #292297
Replied by andypugh on topic Linuxcncrsh - set mode mdi every time?
I have not heard of this as a problem before, so don't know if you are seeing normal behaviour.
Possibly changing the teleop mode might help (but this is just a proposed experiment)
What mode is the system resetting to each time? Is there a GUI on the other end? does changing the mode in that have any affect? Some GUIs might habitually switch mode at the end of an MDI move.
- Thank you received: 2176
10 Jan 2025 08:13 - 10 Jan 2025 15:31 #318622
Replied by Aciera on topic Linuxcncrsh - set mode mdi every time?
@Cong
Double post deleted
Double post deleted
Last edit: 10 Jan 2025 15:31 by Aciera. Reason: Was a double not a triple post
Time to create page: 0.148 seconds
