Abssolute Encoder Homing
01 Feb 2024 11:50 #292133 by akg1904
Abssolute Encoder Homing was created by akg1904
I have a 5-axis machine running on Ethercat and everything seems to be fine.
But I have a doubt
I have Absolute Encoder motors and I have specified that in my INI file by addingABSOLUTE_ENCODER = 1HOME_ABSOLUTE_ENCODER = 1
But during homing on C-axis why it rotates as many turns as it has taken during a G-code program. Why can't it just go to home position in single turn as C-axis is rotational axis(360 degree).
Regards
Abhishek
  • Moderator
  • Moderator
01 Feb 2024 12:02 - 01 Feb 2024 12:04 #292135 by tommylight
Replied by tommylight on topic Abssolute Encoder Homing
That all seems correct, that is the way an absolute encoder/system should work, it will always home to whatever value it was set as home.
Maybe there is a way to reset the home value, but i do not know about it.
Edit:
Removing HOME_ABSOLUTE_ENCODER = 1 would probably make it possible to use "immediate homing", if that is something that works for you.
Last edit: 01 Feb 2024 12:04 by tommylight. Reason: more info
Time to create page: 0.518 seconds
