save the last machine coordinate
10 Feb 2024 11:53 #292985 by Thayloreing
save the last machine coordinate was created by Thayloreing
good morning guys. I'm a beginner in Linux cnc, I hope you'll be patient with me, my question is the following, I used mach3 for a long time and I'm switching to linuxcnc, one thing I missed was the option to save the last coordinate of the machine, so when I turned on the machine and it was always at the reference I had left, is there a way to create a button on the axis to save the last coordinate?If so, could you tell me how in the most explanatory way possible?I'm Brazilian, and I have to translate to understand, so some things get a little confusing.
  • Moderator
  • Moderator
10 Feb 2024 14:15 #292995 by tommylight
Replied by tommylight on topic save the last machine coordinate
LinuxCNC does that automatically even on power cut, just add this line to the ini file, [TRAJ] section:
POSITION_FILE = position.txt
The following user(s) said Thank You: Unlogic
10 Feb 2024 18:35 #293023 by Thayloreing
Replied by Thayloreing on topic save the last machine coordinate
I added the line, as you mentioned, but it didn't work, it opened, but when I move, close Linuxcnc and open it again, it lost all references,
and the coordinates return to zero
  • Moderator
  • Moderator
10 Feb 2024 19:49 #293032 by tommylight
Open the config folder using file browser, see if there is a file named
Position.txt
If not, create an empty file using text editor like mousepad or xed or nano ( not office stuff), and name it position.txt and test again.
The following user(s) said Thank You: Thayloreing
10 Feb 2024 20:38 #293036 by zz912
Replied by zz912 on topic save the last machine coordinate
Here is example:
github.com/LinuxCNC/linuxcnc/blob/54bca1...apy/gmoccapy.ini#L92
You can try it. It is sim configuration. You have this configuration file in your instalation.
10 Feb 2024 20:48 #293037 by Thayloreing
I managed it, thank you very much, but I have another question, in Mach3 if I close and open it and want to run the program without referencing it would use the previous reference, Linuxcnc has to reference it again, is there a way to make it keep the last reference after closing and opens again, the position it maintained when it opens again, but the reference does not
11 Feb 2024 02:10 #293051 by zz912
Time to create page: 0.193 seconds
