Latency spikes on Dell Optiplex 7060 (i5 8500/32GB Ram, Radeon R5 430)
2 years 8 months ago - 2 years 8 months ago #293511 by zmrdko
Hi folks.
I am running linuxcnc 2.9.2 on debian bookworm (kernel 6.1.0-18-rt-amd64) on DELL Optiplex 7060  (i5 8500/32GB Ram, Radeon R5 430)
and I am getting nasty latency spikes (300 us), while alt-tabbing or basically moving windows. If I dont touch anything, latency is consistent around 0 for minutes.
Once I start resizing latency-plot window or launch firefox I get latency spikes.
Do I have issue with video driver? lspci -vv says Kernel driver: radeon, Kernel modules: radeon, amdgpu.
I tried different servo threads - from 125000 to 1000000ns.
is there a way to exactly trace, what caused the spike?
(grub config is isolcpus (tried 2,3,4,5 or 4,5 or even 5 only) idle=poll processor.max_cstate=0 intel_idle.max_cstate=0
everything is turned off in bios (there are c states explicitly)
could it be M2 ssd disk?
Please help!
Last edit: 2 years 8 months ago by zmrdko.
2 years 8 months ago #293514 by mozmck
The following user(s) said Thank You: zmrdko
2 years 8 months ago #293523 by tommylight
2 years 8 months ago #293527 by rodw
I am with Tommy. It sounds video card related. Remove the Radeon card and use the onboard video
as far as isolcpus go on 6 cores, I don't know what is correct, I think that script is the best option as i think it queries the system to decide which cores to isolate.
2 years 8 months ago - 2 years 8 months ago #293541 by zmrdko
I removed Radeon card and spikes went away, even though the latency triangle is more obese now:
2 years 8 months ago #293543 by zmrdko
The situation is same on both Optiplexes: 7060 and 5050, since they both have radeon graphic cards. I would guess it's caused by some kind of power saving feature.
Is there any hack how to tackle with radeons?
Or should I get some older radeon? Or is there any verified gpu that works fine?
Time to create page: 0.200 seconds
