Latency spikes on Dell Optiplex 7060 (i5 8500/32GB Ram, Radeon R5 430)
2 years 8 months ago #293675 by zmrdko
Servo period "must" be 1000000 (1 million), changing it changes a lot of other stuff like PID values.
But I am trying to run 8kHz thread to match with my Delta B3 EtherCAT cycle time.
2 years 8 months ago - 2 years 8 months ago #293678 by Aciera
Ah, Ethercat. Have you seen this (says in the comments that he has not been able to run 8kHz with the newer 6.xx kernel):
Last edit: 2 years 8 months ago by Aciera.
2 years 8 months ago #293752 by zmrdko
Yes, I have seen probably all linuxcnc videos on youtube :)
I was hoping that after two years, technology has advanced so much, that it should be possible to run 8kHz again.
check out latest overnight tests (with internet disconnected - no usb wifi adapter or ethernet connection):
2 years 8 months ago #293757 by tommylight
Should be doable, i did 4kHz easily, so give this a try on a fresh install:
forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity
2 years 8 months ago #293761 by zmrdko
Let me know how it went. Maybe we can compare hardware and do the same tests.
I have bought PS2 keyboard and mouse on saturday.
I was thinking about getting non-ecc unbuffered RAM, but now when I think about it, I dont have bad latency. The only problem is ad hoc latency spike, which will probably not be solved by faster RAM..
2 years 8 months ago #293826 by zmrdko
Overnight test with disconnected internet and using new ps2 peripherals ended up with one minor 29us spike
Is there a way to trace it?
Is it worth to worry about it?
Time to create page: 0.069 seconds
