Stepper motor powering on but no motion
20 Feb 2024 23:38 #293871 by Ronatron42
Stepper motor powering on but no motion was created by Ronatron42
I have LinuxCNC 2.9.1 running on a raspberry pi 400 with Debian 12 "bookworm" (just for bench testing will update to desktop when I get everything installed on actual machine) and wired to a Mesa 7i96s.
The 7i96s is connected to a Stepperonline DM542t and then to a Nema 23 stepper motor set as the X-axis.
I have everything installed and ran the mesa config tool and show a connection to the 7i96s.
When I power everything up I get power to the stepper motor, I know this because it gets frozen and I cant spin it.
The 7i96s is wired to the driver as follows:
step0---> Pul-
Step0+ --> Pul+
Dir--> Dir-
Dir+ -> Dir+
I am not sure where to start in trouble shooting this and any insight would be helpful.
Thanks.
21 Feb 2024 05:21 #293894 by PCW
Replied by PCW on topic Stepper motor powering on but no motion
The most common reason for no motion in step/direction
systems (assuming correct wiring) is too-short step lengths.
I would try setting the step length to at least 5 usec
21 Feb 2024 17:15 #293913 by Ronatron42
Replied by Ronatron42 on topic Stepper motor powering on but no motion
I connected a multimeter to the dir+ and dir- ports on the 7i96s and I get a 5 volt reading. When i try to jog the machine there is no change in the reading.
21 Feb 2024 17:43 #293914 by PCW
So if you jog in different directions, you get no change in the direction output for that joint?
If that is the case I would verify the hal/ini files joint mapping and
also check for watchdog bites (red light on 7I96S)
Do you get any errors?
21 Feb 2024 21:02 #293925 by Ronatron42
I reinstalled linux cnc and started from scratch and I am getting errors.
Unexpected realtime delay on task 0 with period 100000
Run the latency test and resolve before continuing
hm2.hm2_7i96s.0: error finishing read! iter=6
21 Feb 2024 22:32 #293933 by PCW
"Unexpected realtime delay on task 0 with period 100000"
If 100000 (100 us) is your actual servo thread period, this should
be increased to 1000000 (1 ms) or even 2000000 (2 ms) for a RPI4
Also the RPI 4 typically needs isolcpus=1,2,3 and force turbo to get
decent latency
21 Feb 2024 23:09 #293935 by Ronatron42
Ok, I've searched a good amount how to do the isolcpus and force turbo is there a good reference anywhere on how to do that?
21 Feb 2024 23:58 #293940 by PCW
There's probably info in a thread here but I was able to
find out about force_turbo and isolcpus by googling for:
rpi isolcpus
rpi force_turbo
22 Feb 2024 00:04 #293941 by Ronatron42
Awesome thank you
24 Feb 2024 06:23 - 24 Feb 2024 06:24 #294180 by machinedude
Replied by machinedude on topic Stepper motor powering on but no motion
i had the same issue when i first hooked up these drives. these drives have a dip switch setting from the factory being set at 24V on the step and direction signals. switching to 5V solved the problem,
Last edit: 24 Feb 2024 06:24 by machinedude.
Time to create page: 1.360 seconds
