How do I find out what setup I'm using (dialect, post-processor, etc)?
2 years 8 months ago - 2 years 8 months ago #294607 by vchov
Hi, I'm looking for your help doing some detective work. I'm a member of a makerspace and am told that one of their woodworking CNC routers uses LinuxCNC, but am having trouble getting a definitive answer on how to set up a FOSS CAD/CAM workflow for it, or at least one that runs natively in Linux. My guess is that multiple people worked on it over the years so knowledge on it is fragmented.
Can you please offer advice and/or resources so I can find out more about this setup and how to use it? I have some experience using their more turnkey CNC routers and proficiency in using Linux, but very little as far as setting up and troubleshooting a CNC.
For example, I want to find out: what software/firmware it's running, what dialect of g-code it uses, how to choose a post-processor for it, etc.
What I know about the machine:
I'm told that we're using either a modified Gerber Sabre 408 or a modified "pre-production prototype" of it where they completely replaced the controller with one that's used by LinuxCNC. One member said that it uses "G64 Path Blending", although I'm not sure what that means.
There are some computers with VCarve Pro on them and I found that the post-processor mentions "EMC2-G64 Arcs (Inch)". It looks like it might not have come with VCarve, but I don't know where it could have come from and what if any, modifications were made prior to importing the PP. VCarve Pro exports its g-code as *.ngc files.
Thanks a lot for the help!
Last edit: 2 years 8 months ago by vchov. Reason: Got full name of post-processor according to VCarve
2 years 8 months ago #294659 by spumco
Part 1
Assuming you can access the Linux desktop, open a terminal and type
uname -a
The response will identify the kernel version the system is running.
Next, type
linuxcnc
This will start linuxcnc and a window will pop up which allows you to select a user interface (configuration selector).
In addition, the terminal (which is still open) will display the linuxcnc version.
Copy the results of both of the above terminal responses and paste them here.
Part 2
Open a file manager window and navigate to the linuxcnc\configs directory.
Inside that directory you should see one (or more) sub-folders. That sub-folder contains (among other things) the files which tell LCNC everything it needs to know about your machine (i.e. what user interface to use, how many axes it has, how fast it can go, etc.).
Look for a file which ends in ".ini", as well as a file which ends in ".hal".  There are likely a few HAL files in the folder.  If there is one that is larger than the rest - and it's probably named the same as the INI file - those files will help us understand exactly what you've got going on.
Attach the two files (INI and HAL) along with the terminal results and post back to this thread.
2 years 8 months ago #294662 by Cant do this anymore bye all
FreeCad is one solution for your CAD\CAM.
If you need to know about supported gcodes you can always look at the docs.
If you’re running a Mesa controller in place of a grbl controller, firmware version isn’t an issue. Mesa isn’t in the habit of updating (or having to update) firmware everyday that ends in a “y”.
If the machine is working and doing it’s jib without any issues don’t mess with it, it’s easy to mess things up and dig a deeper hole. Even if it’s running on a EOL version of Debian and an old version of Linuxcnc I’d leave it be. Basically if it works, don’t fix it.
The best thing you can do is back up the machine configuration.
Just don’t make changes for changes sake and mess it up for everyone else. And if you do make changes make absolutely sure that anyone using the machine is well aware. Like any tool a cnc machine is not a toy, not a tool everyone can use and can bite, bite so bad a trip in a big white van with flashing lights may not be out of the question.
The following user(s) said Thank You: zz912
2 years 8 months ago #294663 by Cant do this anymore bye all
There’s no real need to have a Linux solution for cad\cam.
In any case I’d be asking what the other members prefer, what they use.
Cambam isn’t a bad little program, runs on both Windows & Linux and has some basic cad features.
FreeCad can be a little frustrating due to the topological hierarchy, it can do some up expected things if you aren’t careful. The CAM portion isn’t as mature but is coming along.
Librecad is quite capable for simple 2d things, along the lines of early Turbcad.
If you’re proficient in Linux I’m guessing you have the wherewithal to do some searching and evaluating of the various packages out there.
2 years 7 months ago #295468 by vchov
Okay thanks a lot, and sorry for the delay!  I just got to visit the makerspace.
Part 1
uname
returns the following:
Linux gerber 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
When I type in linuxcnc into the terminal, I saw this:
LINUXCNC - 2.7.14 Machine configuration directory is '/home/mh/linuxcnc/configs/my_LinuxCNC_machine_2' Machine configuration file is 'my_LinuxCNC_machine_2.ini' Starting LinuxCNC... Found file(REL): ./my_LinuxCNC_machine_2.hal Found file(REL): ./custom.hal
Part 2
There were indeed multiple INI and HAL files in the config folder.  The contents of the config folder are as follows:
backups/ tool.tbl.bak tool.tbl shutdown.hal postgui_call_list.hal my_LinuxCNC_machine_2.ini.bak my_LinuxCNC_machine_2.ini my_LinuxCNC_machine_2.hal linuxcnc.var.bak linuxcnc.var custom_postgui.hal custom_gvcp.hal custom.hal autosave.halscope
I attached the largest HAL file and its associated INI file since the HAL file is ~300 lines long and the INI file is ~200 lines long.
Thanks again!
2 years 7 months ago #295474 by tommylight
It is using a Mesa 5i25 that is inside the PC and has a DB25 port that is the same shape and pinout as a parallel port, but much faster and is wired to a Mesa 7i76 that is on the machine, the stepper/servo drives are wired to it and so are input/outputs, sensors and spindle.
For simple 2.5D stuff look at Inkscape, it is very easy to use and can export gcode that LinuxCNC works perfectly with.
The following user(s) said Thank You: spumco, vchov
Time to create page: 0.303 seconds
