CH382L, M.2 to PCIe adapter on SBC not recognised by Linuxcnc
2 years 7 months ago #294962 by Mecanix
OP obvi picked it up from raspi.debian.net then... there's no raspi stuff in their 64b netinst, trust.
2 years 7 months ago #294963 by Cant do this anymore bye all
$ lsmod
How does your kernel drive it?
Those values relate to the PCI ids not port addresses.
In turn those values relate to the jumpering of pins 62 & 63 of the CH382L. To get PCI id, 3050 which is suported by a Linux driver, pins 62 & 63 need to be shorted to ground. (Bari has mentioned this in a couple of posts on the forum, a google search brings this info up as well)
So in short in very well could be a manufacturer hardware implementation. This type of board does seem to be an issue, some boards do work some don't.
One thing I would do is to insert a known working PCIe card of any type, LAN card might be best as Linux recogonises almost all, if this works you can rule out the first link in getting this to work.
Another idea is to get the PCI ids from the working windows installation, this will give an idea.
There's so many variables to this issue.
Another option and probably less hassle, is to install a second ethernet card and use a 7i92, a little more in $$, but you get more io, and latency is not such an issue.
Or if size and Parallel Port is a must a HP610 Plus thin client, has an inbuilt Parallel Port and an extra PCIe socket, might be work looking at. But maybe not something you'd want to do.
2 years 7 months ago #294964 by Mecanix
Really should pick it up from the array of installed port(s). The great addy "0" in this case. If it doesn't it obviously ain't parport'io'ing today...
Great day to rid the raspi weirdness methink!
2 years 7 months ago #295014 by arda
At first, I also thought "skipping btf" may not be relevant like you said and I moved on with the installation. Then I checked with commands and tests and there were still no sign of success. "skipping btf" was also mentioning "wch.ko couldn't be created" though.
I downloaded and installed LinuxCNC 2.9.2 Debian 12 Bookworm PREEMPT-RT ISO from linuxcnc.org. I have no idea where raspi stuff came from. So I'm wondering if the issue is related to the driver as I wasn't able to successfully pass that stage.
2 years 7 months ago #295017 by Cant do this anymore bye all
raspi stuff comes from a broken debian installer. Has nothing to do with drivers of any sort.
2 years 7 months ago #295019 by tommylight
It is included, still, despite hundreds of reports this has not been fixed.
So not anything you did.
If you want to exclude this as a cause, try this
forum.linuxcnc.org/9-installing-linuxcnc...int-debian-edition-6
Time to create page: 0.695 seconds
